L4310 Steering Assy loose
Demodiver
L4310 with LA681 Loader (other general equip)
Feb 26, 2025
NW TN
I just bought an L4310, 4x4, HST with a LA681 loader on it. It's got about 2,000hrs total.
I noticed the front tires would move around a little before buying it and took a look. I found a couple tie rods that were worn out and figured that is the cause. Got it home and started into it and I found that the steering assembly moves around on the main shaft. The power steering unit is leaking too.
Here's my main question before tearing into this. Are the bushings (parts 070) likely culprits of the play on the shaft or is this more likely the shaft itself (150) or the bracket (020)? Diagram attached.
Is this a common issue? Is there a rebuild kit or are parts hard to find, etc...?
Thank you!
6,877
Welcome! No way of knowing without getting to it, but the bushing should wear before the steel shaft. Parts should be available at your nearest dealer, or Messicks or Coleman Equipment are dealers and will mail out parts.
My BIL has the same tractor. It's a workhorse!
ruger1980
L4310 w/La682, L225
Oct 25, 2020
520
206
CNY
There's really quite a bit that can wear in the steering assembly. And those areas probably don't see the amount of grease that they should. Yes the bushing 070 and the shaft can be worn as well as the thrust washers. I suspect you will find all the bushings both 070 as well as the bushings in the rod and barrel side of the steering cylinder worn. I have see the tie rods also loose in the steering arms and that makes for a bad situation as they will never be tight once the tapered hole is wallowed out.
Worst case scenario is that the pins have wallowed out the bores in the front frame. The only way to fix that is a new frame or welding and boring them back to size.
Tell us how yours is once you get it apart. I will let you know how bad mine is whenever I get to tearing it down.
9,143
Thank you!
Which is leaking?
This is the steering cylinder:
This is the steering controller:
Demodiver
Feb 26, 2025
NW TN
@D2Cat yeah, it moves around a good bit. I've got the bushings, seals, and washers on order now. Appreciate the feedback. Thanks!
Demodiver
Feb 26, 2025
NW TN
@ruger1980 thank you for responding. After reading your post I got back under the front for a better look. I think you're right that the shaft may also be worn. I'll get one ordered in the morning. If you look closely in the pic's you can see that the shaft looks like the frame has worn it down some.
Demodiver
Feb 26, 2025
NW TN
@North Idaho Wolfman The steering cylinder is leaking for sure - I think. The above pic's show the fluid from the cylinder on the pitman arm, etc... If it's not too hard I'll rebuild it. Never done one before, but I do have a local hydraulics shop I can take it too if necessary.
Is there another hydraulic cylinder tucked in there somewhere? If so, I need to take another look to be sure.
9,143
Which l4310 do you have?
DT, GST, HST, DT-C, GST-C, HST-C
N3BP
Sep 20, 2016
499
227
Lebanon, PA
It's not uncommon for these steering cylinders to leak. I just had the one on my L3010 rebuilt last year due to leaking. It was an easy rebuild for the local hydraulic shop. The chrome on my cylinder was pitted, and that's what was causing my leak....
Demodiver
Feb 26, 2025
NW TN
Onee of the reason I ask is that it's also common for these models to leak on the HST cooling lines, so check that, as they are above the steering cylinder.
Thanks. I did see a small cooler mounted along with the radiator, but I didn't give it a good inspection since I was focused on steering. I'll take a look.
Demodiver
Feb 26, 2025
NW TN
Update: After thoroughly cleaning everything up in the front end I never did find a leak up there. I did repair leaks on the rear left axle seal, pto seal, and sight glass.
Almost all of the play in the steering was due to a worn shaft plate (part 170). Some was due to the RH Tie Rod too.
