Bx25 HST not working at all/ball bearings fell out while draining.
Bx2200guy
Bx2200
Feb 23, 2025
New Richmond ohio
So I am working on a bx25 for someone, said he was driving and noticed the hst getting weak, then suddenly just stopped working all together. Will not go forward/reverse. Upon draining the hydraulic fluid the was some small metal shavings that came out as well as a few very small ball bearings and a piece of the bearing. The ball bearings were about half the size of a skittle (candy). Looking for input on if someone possibly knows where they might of came from and if anybody has experienced something like this. I plan on splitting the rear end open to investigate but would like just alittle more information on it.
5,160
Since the tractor isn't yours, and you don't appear to have any experience with the hydrostatic drive on this tractor, you might be going down a rabbit hole that is going to cost you a lot of money and have an unhappy friend or customer. I would explain what you found when draining the hydro fluid and let him decide if he wants you to attempt to fix it or leave it for the experienced mechanic at the Kubota dealership.
When I had my shop I turned away work because I didn't have the experience to do the job. I knew that some of these jobs were turned down by more experienced people because of past experiences with the type of repair needed and the time it took to do it correctly.
Bx2200guy
Bx2200
Feb 23, 2025
New Richmond ohio
I do have some experience with hst I’ve split mine open on my bx2200 before and repaired it. But haven’t worked on a bx25. Unfortunately he’s contacted all the local dealers and all of them refuse to work on it. They just want to sell him a complete new rear end. We have a good used rear end to swap under it if that’s what it comes down to. But would rather try to repair the one that’s in it first.
10,678
I think expecting the rear end to be the issue is being very optimistic.
My money is on a failure in the HST.
There isn't anymore to say then the parts diagrams or the WSM should point to all the possibilities of what could go wrong.
Bx2200guy
Bx2200
Feb 23, 2025
New Richmond ohio
I just downloaded the WSM and I will be going over it thoroughly tomorrow.
6,246
curious and confused...yup it's Monday morning.... :rolleyes:
Is #50,i the attached drawing, the drain plug where the balls came out ? if so, hard to see how HST parts could get there
Lots of bearings in the diff case though.
If the 'spare' rear end is complete, maybe swap them and tractor's 'up and running' THEN you can slowly go through the busted unit on your bench ?
Bx2200guy
Bx2200
Feb 23, 2025
New Richmond ohio
I will double check, but I believe it was the furthest drain plug to the rear of the tractor that they came out of.
Bx2200guy
Bx2200
Feb 23, 2025
New Richmond ohio
so I pulled the hst and rear case apart, found some bearings that came apart, 2 on the idle shaft where the hydraulic pump shaft goes through the housing. Surprisingly I have not found any gears that looked damaged. Looked everything over real good and flushed out the case. Just ordered new bearings. Hopefully this will fix my issue.
6,246
curious..can you post the bearing numbers from the drawing? that second picture, bearing missing balls is well '''one for the books'', and it'd be interesting to hear how it failed !!
