BX23S Battery Charging
Scubaduba89
Kubota BX23S/front loader/backhoe/54" mid-mount mower deck
Aug 30, 2024
New York
I'm trying to figure out what setting to put my charger to for my 2021 BX23S.
The charger itself has three settings marked STD, AGM and GEL.
My dilemma is if the battery itself is STD or AGM.
A quick google search for "SMF 26R-560" tells me the SMF is a type of AGM battery. Another search for the part number itself: K7591-61113 brings up batteries that appear to be standard. I cannot find a direct replacement for the battery to get a description of it.
I've included a picture of the battery itself. Any help on this is greatly appreciated.
5,898
While much older, my BX has a standard lead acid battery.
Looked up the part number, and see a different number K2563-96610.
Is a 26R battery, which is same size as mine. I did look into AGM batteries when I replaced mine a while back but went with a standard battery again.
Just speculating yours is also a standard battery. I could be wrong. Should be some specification on other parts of the label.
Not to insult your expertise, but when you say a "charger" be cautious about over-charging your battery.
I typically use a battery "maintainer" which shuts down when battery is fully charged. Often of lower amperage output and I leave the maintainer on for extended periods of time in the winter.
Can easily dry a battery out if over-charged. Even a "trickle" charger can do that.
2,634
I am with RCW 100% - you do NOT want a charger ......... you want a maintainer, old timers called them trickle chargers. Today that are computer controlled - the "charger" sends a signal to the battery to see how well it took that bit of charge and then does that on and off until it is FULLY charged - BUT never OVERCHARGED.
FOR the battery you have stock in your BX - std would be the correct choice.
The SMF stands for Sealed Maintenance-Free
This one does a fantastic job for the cost - I have 8 of these, different versions but they stall plugged in when the tractor, boat, jet skis are not in use!
My battery on my BX is 12 years old and still starts it at 100%
https://www.amazon.com/NOCO-GENIUS1-Fully-Automatic-Temperature-Compensation/dp/B07W46BX31?crid=3DPNI0VK3OXN4&dib=eyJ2IjoiMSJ9.esANIUStGmPiUyvXeDjdacc4C8xN9VGgVI9AruU8Q6zlg45kXRetvmdEfMugkE3_nim4WcDrMDdX5egDNO6TPplEw0XDpLWSei-edLIhJj2kSIZ0LD5OwzCVFVjHOjg3b0BwmxyBpQ_rDQGBFN2y_9LN1vGQauMsPqRCdHdmaYQuOKPV6mc1JkUzOeTkSTZIs4y6lF8AecSG8RzN1zAVEmeX0tg2-TKy0lrdgyzH3J7EhgSeJ8wWk4-ywEcNyJ5V3FclAgTtNSBGj44t7UH6ikdN3zh5lXR9Mh85Y5wE8zdPxO70U7Ock64H1pShYOIThjMdmB2ufiHLJo9oCdgfmgVtLIpf-zwAAMbPpRwk9yv4HJyxXvdbN0oyZYpWYwCz2rzA5dDqkIbDwlPHyNbWUQiaqbMgn0qNmWg_I20LNz3KSKMvcIHofRzYvdGUDX5n.BL00Lq11aYpXagSfautlDxgWnnSEWQElDAFYg1zFvP8&dib_tag=se&keywords=noco+genius+charger&qid=1740255877&sprefix=genious+char,aps,133&sr=8-8
5,898
I changed my BX battery not due to performance, but was 8-9 years old. Didn't want a surprise with 2 feet of snow on the ground and I needed it for snow removal.
I've heard good things about the NOCO maintainers @85Hokie linked.
I got 11 years out of an OEM battery in my Harley Davidson motorcycle. Was on a Battery Tender for much of those years in Upstate New York. Motorcycle batteries are often a 3-4 year item in cold weather. Never took it out.
Scubaduba89
Aug 30, 2024
New York
Thank you for the response!
No hurt feelings here. I did mean a maintainer. Just need to keep some juice in it to clear a bit of snow here and there.
I meant to order a user's manual for the tractor and never got around to it.
The battery label itself doesn't have any more info. I pulled the battery to double check if there was a label on the backside.
Scubaduba89
Aug 30, 2024
New York
I appreciate the response!
That was a slip on my part. I will be using a maintainer.
I was starting to believe it was a standard, but everything I looked up info on smf I started seeing it was a type of agm. Always good to have a reminder that a quick google search isn't always the answer.
Thanks again for the information and maintainer suggestion
5,136
Check the back of the seat back. That is where the manuals are stored from the factory. Unless someone took them out and didn't replace them, they should still be there.
John T
2017 BX23S
May 5, 2017
924
401
under a rock
Thats a WET battery ... (lead acid)
Same one I have in my 2017 BX
And as mentioned above .... It's sealed... so called maintenance free.
