L2850 advice please.
P0tt5y
L2850 with BF500
Feb 16, 2025
Great Britain
Hi guys,
So I’m new to this forum, I’ve recently purchased a L2850 with BF500. Prior to that I have also a B8200 with BF300, which I’m looking to sell on.
Im after any answers/advice please for the L2850 on the following;
I need to plumb in an aux feed to the rear for an off-set flail topper/mower and a wood chipper. Is there a kit out there for this?
I will also need to remove the front loader while mowing. This is due to the quite steep slopes and I want to keep the centre of gravity as low as possible. Is there suitcase weight or a ballast system that can fit on the “loader mounting bracket”? I’ve not yet had chance to dis-mount the loader and see what this looks like.
Im based the other side of the pond and greatly appreciate everyone’s experience, advice and tips.
Kind regards.
2,964
I am somewhat nervous providing information for your tractor. The European models are often different than the models in the USA. Please be sure the information is correct for your tractor. Here is some information about the hydraulic system on your tractor.
Normally the FEL has a power beyond port that can be used for the rear remote power in. Then the rear remote has another power beyond port that then feeds back to the tractor block that powers the three point hitch. Bothe the FEL and rear remote would also have a tank return that returns the cylinder fluid to the sump.
10,773
I do believe this is the same model as the US model.
Just to be sure @P0tt5y give us a picture and / or a serial number.
10,773
Yep same as US model.
There is not a Factory kit available that will add the rear remote, but there are generic kits in the US that will do that I don't know who you would get one from over there.
You simply take a line off of the PB of the loader valve and back to the Rear valve then back to the block in your picture. You would also tee into the tank line.
The valve you would need would be an open center valve with PB.
You could do electric or mechanical valves.
2,964
If you have any other questions just ask. You can search and find the answers to the installation since there are many threads on here about installing rear remotes. I suggest you install two or three slide valves and not just one. Not much in cost and easier now than later.
Hopefully you have a mounting location that is convenient. Please do post back and show us what you end up doing.
Firefight100
MX5200
Apr 3, 2021
111
82
63379 troy mo
I had a 2650 that looks like yours. If you remove the loader and find the 3 point doesn't work, that screw with the snap ring in your 1st pic has to be turned when the loader is on or off the tractor.
