hello
26Troadster
L3240
Feb 18, 2025
Alabama
i didn't see a intro area, so i'll do it here, i'm 26Troadster. i have a L3240 and the upper three point hitch point on the back of the tractor is a pita to get the drawbar pin in and worse to get out does anybody make a extender link or is this a diy thing?
10,700
Is this what you talking about?
And have you extended it out for easier attachment?
And what are you attaching to it?
26Troadster
L3240
Feb 18, 2025
Alabama
ok say i put the box blade on the tractor, i have three points to pin to. the upper bar pins into a mount in between the lift cylinders and they are in the way of getting the pin in and out of. i call it the drawbar mount cause i can adjust the drawbar to adjust the angle of the box. i will stop and get a pic this evening.
26Troadster
L3240
Feb 18, 2025
Alabama
not my tractor but it shows close to what i'm talking about. maybe i should call it a turnbuckle. where it pins on the tractor is stuffed between the lift cylinders. i will get a better pic on the way home.
PHPaul
Apr 2, 2015
1,243
1,503
Downeast Maine
www.eastovershoe.com
The trick is to put the tractor end of the top link in first. Lift the hitch enough to get the pin in, stow the top link in the provided hook and THEN lower the arms to attach to the implement.
2,910
You may have a pin that is not original and too long to be easily removed. But it could be just a tight space in there. You may want to buy a new pin from the dealer if the are not too expensive.
26Troadster
L3240
Feb 18, 2025
Alabama
thanks folks this is just a really tight area, and it is the original pin. looks like i'll fab something for it. sorry i have to walk with a walker and the weather was foul so no pic yet.
10,700
That's an even greater reason to get a Quick Hitch!
jaxs
B1750HST
Jun 22, 2023
1,033
792
If I follow what you are saying,does your top link screw in and out same as one shown in the picture above? I have to screw mine in/out most every time I hook/unhook implements. Hard to do while sitting on tractor.
retiree-urgency abandoned
B3350, Kub. 5" rotary cutter, LP 48" forks, Titan Aerial Platform, KK XB Dump
Dec 1, 2020
108
114
Bloomington, IN
I agree with jaxs - the top link (screw in/out) does help to get things lined up. I've got a quick hitch and even with that, top link adjustments are usually necessary to get things lined up to mount an attachment. Since I've got a rear hydraulic remote I'll probably eventually add a hydraulic top link, to make it easier to line things up without getting off the seat. As I don't do much fancy grading, I'd probably start with the hydraulic top link - if I ever need a hyd. side link I could add that later with another rear remote.
With a walker, you might want to consider both the quick attach and a hydraulic top link - might save you a lot of getting on/off the tractor.
On a related note, I've got a pretty heavy rear blade. Given the weight, I've always removed the 3PH quick attach and pinned the blade directly to the 3PH toplink & arms. Am curious if others are using their rear blades with the quick attach and if there are any problems.
jnschnit
B2601, BH70 BH, LA435 FL, RCK60-32 MMM, BX2763 Blade, ZD1011
May 10, 2013
138
46
newark valley new york
I always leave my top link on the tractor just because of the reason you describe. Same problem with my B2620 and my B2601. Like Wolfman mentioned you may want to look into a quick hitch if you change out your 3pt attachments often.
