Frozen Hydraulic Couplers
5,164
Today I tried to connect the two flat-faced couplers to my 3rd function valve, but they wouldn't seat. Finally, in desperation, I poured boiling water on them and miraculously they coupled with no effort. Does this mean that moisture has gotten into the couplings or is there water in my hydraulic fluid?
11,757
I've removed and installed the front hydraulic snow blade twice in the past week and both times I struggled a bit disconnecting and reconnecting the hydraulic lines. Water gets in under the spring loaded collar and freezes, which causes enough interference to make it harder to compress the collar spring or at least to move the collar. I didn't need hot water though but it was certainly more work that it would be in warmer weather.
John T
2017 BX23S 385XP Miller211 1952 Panhead Orange Ludwig 4 piece
May 5, 2017
1,306
819
under a rock
If it IS frozen.... I'd probably warm it up with a small bottle torch rather than pour hot water on it.
Papadiver
BX2380 FEL, MMM, 3rd Valve, Grapple-Grand L4060
Feb 10, 2019
125
147
WV
Using heat….Good idea! I have a china heat gun that uses DEWALT batteries. I think I found another use for it!
5,164
It was below 0 degrees, and I wanted to finish cleaning up the driveway before the slush changed to ice, and hot water was readily available, whereas my plumbing torch wasn't. Based on what McMXi explained as the cause of the problem I am putting the rubber covers on them now when the hoses are removed.
BAP
Dec 31, 2012
3,175
1,293
Make sure if you put the covers on that the hoses hang so that the open end of the cover is facing down, otherwise the cover will get moisture in there and cause the coupler to freeze.
11,757
I would even consider putting a plastic bag over the 3rd function fittings when they're not being used to keep them free of snow and ice. Without snow and ice there's no water to get under the collars and freeze.
I don't know if this came across in my earlier post, but the hydraulic couplers can freeze even when they're connected to the 3rd function hoses. I was able to disconnect the lines the other day, but moving the collars and compressing the springs was more challenging than it is in nicer weather. The following day I reconnected the lines and the collars simply don't want to move as easily, which I attribute to snow melting on the fittings, and water working its way under the collars and freezing.
11,757
The problem of frozen or hard to disconnect/connect hydraulic fittings when it's cold shows up in various pieces of equipment. I was watching a YouTube video yesterday and the host of the channel was trying to disconnect the "wet" lines that connect to his lowboy trailer. He needed some heat in order to disconnect the lines.
MapleLeafFarmer
Lots incl. B and L kubotas
Dec 2, 2019
1,167
1,158
E.
I think your problems not too uncommon as around my parts we get same type of problems on occasion as when the hydraulic fluid gets warm the hoses / couplers / etc... also get a little warmer and when snow hits / sits / rests on the coupling a slight melt can occur freezing into them.
I keep an old hair dryer in both my shops that seem to get the work done as i'm too cheap to buy battery operated hot air guns, etc... I admit I am old and cheap so I make do with what I have kicking around and easy to get my hands on over the years cheaply.
6,285
Spraying some WD-40 and cycling the 'collars' a few times 'should' get rid of the water/ice issue. That IS what WD was designed for...Water Displacement.
I've used RustCheck for years as it lubes and lingers...
