Adding rear lights
rkh Kubota
Kubota L3302DT
Sep 30, 2024
20
Pennsylvania
I have a new Kubota L3302 and the red lights on the rear aren't bright enough at nite. What light for the rear do you guys recommend? Do I go with LED and can you connect to the rear light?
Speed25
L2501(sold) - BX25D
Apr 23, 2024
318
504
NC
I'm assuming you're just looking to be more visible, or are you trying to light up the surrounding area more?
7,307
Yes, back lites aren't bright enough
I replaced all the bulbs on my older BX with LED.
Many (not all) tractor bulbs are common automotive bulbs and can be found in an auto parts store.
If you look at the parts diagram and part number for your tractor you may find a clue about an LED replacement.
Only an example, I think I found I had incandescent bulbs that were 1156 or 881 in their description. Both are common auto bulbs. I was easily able to find 1156 or 881 compatible bulbs at NAPA or Advanced Auto.
It is worth doing. I have to get in the road for snow work. I’m a lot more visible both night and day now!👍
My garage is very bright, and the bulbs all show easily.
7,307
Did a quick search of you taillight bulbs. Look like conventional auto bulbs, but didn't find an auto version number or LED equivalent quickly.
I'm 98% sure they're easily gotten.
I would take one out. Take a trip to an auto store and compare. Betting you can find an LED version, or a least find what bulb model number it is.
airbiscuit
Mar 18, 2021
390
447
NW WI
To be clear, you are only looking at making your RED lights brighter?
Or, are you ALSO looking to put a rear facing work light (bright white) on?
je1279
Dec 6, 2020
828
585
Upstate NY
If your interested in increasing the output from either your front or rear lights, high quality LED's will certainly help. I added led headlights, taillights and lollipop lights to my LX2610 for the sole purpose of being more visible when I'm plowing snow near the road at night. I also added a LED beacon and forward and rearward facing auxillary LED light pods.
airbiscuit
Mar 18, 2021
390
447
NW WI
The OEM Bulb is spendy!
lmichael
Kubota G2160
Apr 23, 2021
837
433
Rockford IL area
I retrofitted LED flood lights inside the original housings on my G2160. Really light up my yard when needed. And added LED tail/running lights to the back. I did not want to have anything screwed to the machine so the tails replaced the reflectors that were there.
5,160
I replaced all the lightbulbs on my BX23S with LED bulbs and they are much brighter than the original incandescent bulbs. On my 1962 Chevrolet, I tried the LED bulbs and they helped a lot, but I found that by installing RED LED bulbs, they were a lot brighter. Now the taillights are as bright as the stop lights when I converted to "clear" LED bulbs. When applying the brakes, there is no doubt that I am stopping.
