Woodland Mills TR68 Pro Wood Chipper
nh10ring
Kubota LX2610SUHD
Mar 28, 2022
23
I am looking to purchase a Woodland Mills Woodchipper for my LX2610SU. I will be using it to maintain my 70-acre New Hampshire woodlot which is on a hillside. It contains primarily hardwood, with some mixed hemlock and white pine. I was initially looking at the WC68, but I see they now make the all new TF68 Pro (twin flywheel). In addition to the twin flywheel, it looks to have gas-charged springs, and a chainsaw holder. The only negative I see is that it weighs 50 lbs heavier. What few reviews I can find are positive, but I am unsure if it is worth an extra $900. Have any of you had experience with the TF68 Pro? Or for those of you who already own a WC68, would you consider jumping up to the TR68 Pro if you had a chance to? Would love to hear your thoughts on the TF68 pro.
nh10ring
Kubota LX2610SUHD
Mar 28, 2022
23
Update: Woodland Mills just responded to me, and they do not recommend the 68 model for my size tractor. They suggest that I go with the WC46 or TF46 Pro. Ughhh.... Thoughts about this are welcomed as well. Thank you.
Elliott in GA
Mar 10, 2021
803
808
North Georgia
You might want to look at the WoodMaxx MX-8500G+ chipper - 5 inch capacity and made in America.
It does not have hydraulic feed, but that can be a plus (their blade angle and rolling anvil design pull material in without a pump, belts and adjustments). See my review below.
5,176
According to TractorData, which is usually correct but not always, your B2320 has 17 or 18 PTO HP (depending on transmission), and 3 point capacity at 24” behind the lift arms is a bit over 1000lb. Assuming those figures are correct, I would agree with whoever you spoke to at Woodland Mills, the performance of the WC68 paired with a B2320 is likely to be suboptimal to the point of dissatisfaction due to its weight and HP requirements.
While I have been quite pleased with my WC68, I’m mating it to a tractor with about 38 PTO HP and a bit over 2300lb 3 point lift capacity 24” behind the lift arms. I would suggest going with a chipper better matched to your tractor.
In regard to the old style single flywheel v the newer double flywheel, unfortunately I have no basis for comparison. I know the single flywheel works well. Maybe the double flywheel allows faster feed rates? I have no clue.
GrumpyFarmer
4,238
OP, I use a WC68 on my B (I believe it’s similar size to your machine? I also have a very hilly property. ). My recommendation would be tread lightly when it comes to “big”…its about all the B can handle if you don’t have flat land, and you will need the loader on to safely move around…may need a scoop of something in the bucket depending on what doing. (Steering gets very light) I would not take it down any of my steep hills that I normally would mow.
With the loader on and the chipper off the back it takes up a bit of space. Combine that with the hills and it starts to limit direction of travel. At least it does for me.
I’ve found it much safer to bring the brush/limbs to the location I can safely get the tractor too vs trying to do a milk run and stop and chip along the way. YMMV.
I would buy the WC68 again but I am also not familiar with the other model you mentioned. The one I have works great and I would not tempt fate to put something bigger/heavier on it…running it is no problem…moving it safely on a hilly property with B is the issue. Works great no complaints. It’s like an angry beaver.
(Saw holder is very helpful)
nh10ring
Kubota LX2610SUHD
Mar 28, 2022
23
Thank you for taking the time to post. It brought to my attention that my profile information still had me listed as owning a B2320. I have since traded up for the LX2610SUHD, and updated my profile. The LX has 19.5 HP at the PTO, which is just a tick under the 20 hp requirement of the WC68.
woodman55
L6060HSTC, RTV 1100
May 15, 2022
1,050
869
canada
One advantage to the hyd drive units, is that you can slow down the feed rate. Which I think for your size tractor, would a asset.
nbryan
Jan 3, 2019
1,323
848
Hadashville, Manitoba, Canada
The 19.5 HP is enough, having 6 years of chipping experience with my WC68/B2650 combo.
rh74
LX2610, LA535, BH77, LX2980, RB1672, BB2560, PFL1242
Feb 17, 2024
59
67
Hoosick Falls, NY
I have a Woodmaxx MX-8600 chipper that runs off an LX2610. MX-8600 has the same chipping capacity as the WC-68. I have not had any tractor issues (stalling or being under powered). However I don't go crazy and fill the chute full and have the in-feed roller at full speed. If you go slow with the larger diameter material it will not be a problem. Below are some things to keep in mind.
1. The weight and distance of the chipper hanging off the three point arms. When traveling go slow, don't allow the chipper to bounce and avoid steep or side hill slopes. The MX-8600 unit I have weights 200lbs less that the WC-68. I've not had any issues but the weight on the back of the tractor is noticeable.
2. When chipping go slow with the larger material. Start with small material first and get use to making in-feed roller speed changes.
