1980 B-7100HST damage to transmission case
Damolo
1980 Kubota B-7100 HST
Aug 16, 2024
11
Glasgow, Ky.
sylvanbanjos.com
Hello friends. I have a broken spot where the long pin that holds the two lower links for the 3-point hitch attaches to the transmission case. You can see in the pics that one side has broke free from the case. I've been told it will need to be taken apart (tranny case removed) in order to weld it correctly; clean and also w/o risk of heat damage to internal seals, etc. So I'm looking around right now to hire a mechanic to do this for me, but also considering doing it myself. How big of a job and will the entire tranny need to be removed or is it possible to remove only the rear half (differential case) ? Any advice would be greatly appreciated.
8,790
You don't want to Weld that, it's cast aluminum they do not weld easily or well.
You have to take everything from the bellhousing back off to open it all up.
It's not a real hard job if you have the space and mechanical skills.
3,659
I love welding, but I am not nearly good enough to tackle "cast aluminum".
I tried a to weld a cast iron frying pan one time, and that turned into a funny/sad/debacle of epic proportions.
Needless to say, there is one less of "Grannys antique cast iron pans" left in this world.
I know there are guys that have some crazy "mad skills" and your going to need to find someone just like that, cause from what I know, it ain't easy, that's for sure.
Mountainman
L2501, B7100, B2710 B21, B1750, B2400, B7200
Jul 10, 2022
428
169
Attalla Alabama
mossycreekoutdoors.com
I have several good differential cases here in northeast Alabama. Happy to help.
Damolo
Aug 16, 2024
11
Glasgow, Ky.
sylvanbanjos.com
Thank you very much...looks like I'm in the market for a replacement differential. Sorry 'bout Granny's frying pan! :)
5,711
While a professional 'aluminum certified' welder could do it, another case would probably be a better idea. Welder might spend a DAY doing it, gotta get ALL the oil out. Welding 'virgin' aluminum is easy relative to 'oil/grease' soaked aluminum....
FWIW, I'd fab up two 'helper support plates', 1/4" thick, that bolt into the 3 bolts vertically above the 'tab'. They would add a lot of strength to the unit.
I suspect whatever was on the 3ph 'shocked' the tab and that's why it broke ?
8,790
@GreensvilleJay I suggest you you go back and look that the picture closer, the reason it broke is staring you right in the face!
What is it?
No extra support is needed on these they are incredibly strong if used right.
Bisleybob
B7500
Aug 15, 2020
75
86
Harding Pennsylvania
OP has threaded rod in place of a pin, looks like it's been tightened up, side loading the ears on the case. There should be free play there
8,790
And we have a winner! ;)
I would also bet that rod is not the right diameter either.
Damolo
Aug 16, 2024
11
Glasgow, Ky.
sylvanbanjos.com
Yep, good eye. I'd been using it with the threaded rod for 15 years, never noticed the side loading. Stupid me. So there was that. Then I was pulling a heavy trailer with the hitch--apparently the bolts were loose and the hitch moved allowing the shock to the already side loaded tab.
8,790
Hey no judgement here, we sometimes just do what we have to do, to get by.
Just have Daryl send you the bar too. ;)
8,790
Yes, good idea--Btw what is the diameter of the stock bar? Thanks again for your help!
Maybe Daryl can get you the size my B is currently under 3 foot of snow.
