Summit 3rd Function Kit Applicability to L3130?
BT3101
L3130 GST, FEL, Taylor Way BH W/Subframe, Rotary Cutter, Pallet Forks
Mar 20, 2016
49
108
Evansville, IN, USA
All,
Last week I posted pics of the Titan grapple bucket (48" w/3000 psi cylinder) I just purchased. This week I want to get the hydraulics ordered. I have virtually no experience with this type of decision.
The Summit kit linked below lists most of the current models in the same HP class as my 2006 L3130. I called them to confirm the kit would work for my tractor and the customer support person said "its not on my list... if it doesn't fit, you'll need to pay for return shipping and restocking". Gee, thanks.
The owner's manual for my tractor says the pump puts out 8.3 gpm and 2560 max PSI. These are below the numbers shown in the kit info. Other than maybe fitting sizes, anyone see any reason I can't use this one? Anyone have what they think is a better option?
I'm resisting the urge to buy the Amazon kit that shows the exact same pic and specs for almost exactly 50% the cost of this kit.
Third Function Valve Kit Kubota L2501, L3200, L3301, and L3901
MOOTS
MX6000
Jun 27, 2019
2,008
2,368
Canton, Georgia
What’s the Amazon kit?
The summit kit will more than likely work, fittings are really the only thing that could change. I put the summit kits on two separate tractors not listed in their specs. LX2610 and MX6000 both were fine.
7,297
The issue of it fitting or not is going to come down to the small lines, they might not match what you need on the L3130 valve, but would be as simple as adding a couple adapters to make it work.
The valves and everything else will work fine for what you want and need.
BT3101
Mar 20, 2016
49
108
Evansville, IN, USA
BT3101
Mar 20, 2016
49
108
Evansville, IN, USA
Thanks for the feedback.
I'll update this thread after the fact so anyone searching in the future will hopefully find the information.
