BX2380 got a flat, tire recommendation?
Bruh44
BX2380
Mar 29, 2023
80
17
North Carolina
I ordered the Kenda tire.
I also found a place that fills with foam locally. I think I’ll go that route for now.
Thank you all for your help.
Bearcatrp
Mar 28, 2023
1,361
985
Minnesota
I sliced the sidewall on my front tire on my 1880 from an ice chunk last winter. Tire pressure was about 12 psi from the factory. Since I inflated to max psi, no more issues. But I bought R4’s for winter duties now maxed out psi. No issues now. I had turf tires when I cut it.
3,394
I hesitated to respond, because one member here kind of took offense because I always keep repeating how happy I have been for 20 plus years with foam filling my front tires on both my BX and my B2910.
Small front tires do not cost that much to foam fill if you find the right supplier.
Foam filled tires so not come off the rim, do not need air pressure checked, do not puncture, and if you find the right place, they can adjust the foam to mimic tire pressures, more or less.
Just something to keep in mind. I have been happier than the happiest camper over the years...something to consider...
Bruh44
BX2380
Mar 29, 2023
80
17
North Carolina
I may go that way it does sound good to me. Im just too broke to spend extra money at the moment. On top of having some damage from Hurricane Helene I need to take care of on my house, I am in the middle of putting an addition in my house that has gone far over budget.
I’ll get back to that probably next year.
