Grapple width for LX4020, 56" or 66"?
Outback101
LX4020HSD ROPS, RCF2060, PFL1242, LA545 w/60"
Feb 1, 2025
Northeast Iowa
Looking at the Stinger brand grapples for compact tractors and not sure which width to purchase. Weight difference is less than 50 pounds, both under 400 lbs. What are your opinions? I know everyone has one. :)
CGMKCM
RVT-1100C, ZD323, L4760
Jan 26, 2021
471
268
Randolph county N.C.
I would get the larger one because it will be a little wider than the front tire total width. I like having the grapple clear debris ahead of the tires. I have a 64" on my tractor.
11,757
I have a 60" grapple but sometimes wish I'd bought the 66" version which is 200lb heavier. At the time I only had the MX so it made sense to go with the 400lb grapple vs. the 600lb grapple. The front tread width of the MX is 52.2" but it's adjustable on the M6060 from 55.9" to 59.8". Still under 60" but it does look undersized on the bigger tractor. :giggle:
fc1
L3940
Apr 17, 2024
L3940/66" grapple. The only time I wish it was wider is when I'm using it as a stick plow. Pretty rare, really, so for me the width is good. I think it probably depends on your use cases whether or not the wider one would make a difference.
Nomore67
Currently own- LX4020, B2601, IRE20 (mini-ex). Previously owned- BX1870, B2601
Apr 28, 2019
31
40
Minnesota
There's surely a best choice for each application..... I went with a 54" for my B2601, to minimize weight and to keep it nimble in the woods. I use this same 54" Grapple on my LX4020, with zero complaints! (I did weld in some enforcements between the lower tines though, *after tweaking a couple of them a little)
Donystoy
Dec 10, 2013
735
378
Binbrook, Ontario
I opted for the narrower 56”grapple as it is better at removing roots.
MapleLeafFarmer
Lots incl. B and L kubotas
Dec 2, 2019
1,174
1,162
E.
great question I think probably no right / wrong answers only preferences.
For me I went narrower than front wheels. Its a HD AE root grapple and knowing the type of work we make around our place didn't want anything wider than needed as I was worried about operators using the outside tines which are easiest to see to push on stumps / trees / rocks / end of long downed trees / etc... causing too much twisting stresses on loader arms. If I was to do it again I would still go narrow. Tractor loader arms are flimsy compared to track steers loader arms so trying to be careful on twisting forces.
Looking forward to seeing the rational on why others want as wide as the front wheels but not as wide as the rear wheels? If the objective is to have coverage of a machines track like users of snowblowers/box blades/land planes/rear blades/etc..... and / or protect rubber from stick and other pokes then wouldn't the grapple need to be as wide as the rears?
just thinking out loud.
soloz2
85
80
WNY
I’d go with the 66”. I have a 60” on my B2601 and it’s nice being able to see the edges.
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,960
2,349
Western MT
I think it depends on the load. Messick’s did a video on how you can overload cylinders with leverage. Go shorter to minimize that effect.
mdhughes
L3901DT
Dec 10, 2014
1,464
1,537
Ste Geneveive county, MO
I went with a 55" to save weight. It has worked out pretty good with my L3901DT. I haven't had any problem clearing paths to fell tree with it.
