BX2380 got a flat, tire recommendation?
Bruh44
BX2380
Mar 29, 2023
80
17
North Carolina
I’m in Fairview, NC where the hurricane hit x few months back. I was digging up river rock to fill a couple bad spots in our road.
I’m guessing I hit something metal, because my side wall got split on my front left tire.
Definitely better than a rear tire. I had already replaced this tire about two years ago.
is there a specific brand you all recommend? I’ve been price shopping and found a few that look decent. I would like to get something very durable though.
I’m sure about any tire would get split on sheet metal, but there’s a lot of crap in the ground here. I just want to get some solid tires to deal with all that.
je1279
Dec 6, 2020
834
585
Upstate NY
What style tires do you have? R4's are generally the most puncture resistant if that is your primary concern.
7,717
What's on the tractor now? If you change from R1 to R4 a different wheel is required. Be aware.
11,269
Have them foam filled and be done with it.
je1279
Dec 6, 2020
834
585
Upstate NY
As @DustyRusty mentioned, those are R4's. Your best bet is likely to follow @North Idaho Wolfman's advice and have your front tires foam filled to prevent future punctures.
je1279
Dec 6, 2020
834
585
Upstate NY
I will definitely look into that. I didn’t know that was a thing.
Do most tractor places do that?
I'm going to defer to the others on this as I have never had it done on any of my equipment. However, I'm guessing that any dealer who sells skid steers either can do this for you or knows a place that can.
Bruh44
BX2380
Mar 29, 2023
80
17
North Carolina
So R1 will not fit on my rim? It was mentioned you can’t go from R1 to R4, will it work the other way? Are these good tires? I was mainly interested in them because they have 6-ply side walls. The others mostly have 4-ply.
6,328
R1 = 'farm tractor tire', think old school, the original tread, digs in soil 1st tread pattern out
R4 = 'industrial', think 'skid steer' or NOT used for plowing field, ( less aggressive tread
TURF = well, used for mowing lawns, spreads weight out, so no damage
R14 = the new kid on the block, a compromise tread
I 'think' you can now get R14 from Kubota 'wholesale goods' now. R14s will have more plys (rubber) and better weight capacity ??
KENDA make an 8 ply tire,1100# cap (?). It's an R4 style .Try Google 'kenda and the tire size....)
3,156
Most tire sizes don’t cross over from R1 to R4. You might be able to find R14 sizes that match R1 sizes and another R14 size that replaces the R4 sizes.
