What's your fuel consumption like?
Orange man
Kubota L2502 LA526 loader , woods prd6000 mower, Land pride RB 1672
Jul 23, 2014
260
169
WNY
I have owned a L3200 and two L2501's and none of them had an accurate fuel gauge, all showed empty way before the tank was. I always thought that was a good way of never running out!!
Chanceywd
Mar 26, 2021
848
845
central ny
Mine was the other way. It was half a tank and showing it was only down a quarter.
It would be about a quarter left and still showing half on the gauge.
Always shows more than actual and I worried about running it out.
Bill
bbxlr8
Mar 29, 2021
455
314
Eastern PA
Mine is like this also - 5G takes it from 1/3 to full. Was a bit unnerving at first
4,125
2,821
Bill
I pay more attention to my hour meter. When my low fuel light goes on it means stop doing what I am doing and re-fuel asap or else very soon I'm walking to get a gerry can and bleeding the fuel system.
Elliott in GA
Mar 10, 2021
880
891
North Georgia
About 3/4 a gallon per hour doing PTO RPM work (mowing with rotary or finish mower).
BTW, I top off my fuel tank at the end of my monthly visit to our north Georgia property. You want to avoid leaving a partially full tank for long periods of time. All of that air in the tank can lead to condensation equaling water in your fuel.
Smokeydog
Jun 2, 2020
757
729
knoxville, Tennessee
The mid eighties M5030DT shuttle shift had the best or least fuel consumption for a 50-60hp full-size tractor. Massive inline 6 cylinder engine sipped fuel for tasks like mowing. Lugging low end torque. Compared to more modern M59 compact with turbo charged 4cylinder with lower pto Hp, HST, likes the fuel.
Did measure the B26 running house with 10kW pto generator at 0.6gallon per hour.
7,658
I have no idea of fuel consumption rate. I am always sure to add fuel WAY before I wash and wax it!! ;) ;) ;)
pigdoc
G1800S L2500
Aug 19, 2022
403
349
SE Pennsylvania
I'd just say, check your crankcase oil level. Bosch injector pump seals do not like excessive pump pressure. When the seals blow, the injector pump can start pumping fuel into the crankcase, raising the oil level above normal.
Not sure if your tractor has a lift-pump, and if the feed to the injector pump is by gravity alone, no worries.
-Paul
Mak65
L2501 HST
Apr 25, 2019
150
118
TX
I have a L2501 HST. This past weekend I mowed for 4.25 hours w/ a 5’ mower. I do wildlife management so the fields grow all year and the grass/weeds are thick and tall (some over hood height). The 10 gallon tank was full when I started and it took exactly 5 gallons to refill. So, a bit over a gallon per hour.
My gauge is like some others here. Gauge takes for ever to begin to drop. Read about 2/3 full when I was finished. It should have been closer to half based on above . But, once it shows half a tank the gauge drops like a rock.
John D 2
B2601 LA435 loader, 54inch MMM, carry all, boom pole, fertilizer spreader.
Jun 6, 2023
197
201
While mowing with the MMM, engine at 2600 RPM's my B2601 can run 8 hrs on the 6 gallon tank or .75 gph.
My JD1025 used 1 gph mowing the same area, when I wasn't having to change the PIA inline fuel filter.
No more green for me!!
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
3,278
2,976
Near Lancaster, PA, USA
Rough estimate would be around 1 gallon per hour. I went through 2 of the 3 drums (55 gallon) that I had filled in October of 2023, and put a little over 100 hours on the Kubota. The Ford wasn't used much at all over the past year, so it wasn't drinking more than a tank full or so.
11,757
So I was just curious what your fuel consumption was like on your tractor. How long can you typically go without refueling?
A few months ago one of the salesman at the local dealer told me that Kubota sizes the fuel tank on their equipment to give close to 8 hours of use on one tank under "typical" operating conditions. I did a few jobs for money last summer and was running the MX and flail for about 3-1/2 hours at 2,600rpm with the A/C on and estimated a fuel consumption rate of about 2.8 gallons/hour. This was based on starting with a full tank and then filling up once the job was finished.
I will say that the M6060 seems to sip fuel compared to the MX which has a tendency to guzzle.
ItBmine
B2620, RTV-X1100C
Jan 21, 2014
1,524
553
Well I have no scientific measure but I have a B2620 and to mow my 3 lawns I would have to refuel my gas lawn tractor after using it's 4 gallons to finish, but my B2620 can mow it 13 times on 5 gallons of fuel.
And I can snow blow my 300 foot, 12 foot wide driveway numerous times before I need to fuel. My RTV-X1100C can do the same.
notnew2diy
2004 B7610, Woods rd6000 finish mower, Woods roto-tiller
Jul 15, 2014
45
12
McHenry county, Il.
2004 B7610 PTO work(ruff cut, tiller, lawn) usually takes 1 gal/machine hour.
Don't usually pay attention on how much I use otherwise. Gauge is accurate enough to where I have never ran outta fuel.
YMMV...Don.
Starman2112
Kubota LX2610 / Kubota Z421 54"
Jul 4, 2023
I have a LX2610 and a Z421 Zero turn Kubota. Both have similarish engine HP specs. Im quite shocked at how good the gas milage is on the diesel tractor, I seem to only burn half a tank of diesel after 6 hours of brush hogging on my property (~4 gallons). The Gas zero turn on the other had seems to burn like 5 gallons an hour.
PaulL
B2601, MX5200.
Jul 17, 2017
2,798
1,791
NZ
It's a governed engine. You can be running at PTO revs (2600-2800rpm on my B2601) and using almost no fuel if there's no load, and you can be using a lot if you're working it hard.
Running my chipper, it sips fuel. There's not much load in a chipper other than when you feed it big logs, most of the time it's just spinning with little load. When I mow thick grass fast (which I do quite a bit), I can bog the engine down a little. That means it's run out of throttle to add....I'm working it hard. I'll use about half a tank in 3 hours when mowing hard, that's 10L which I guess is a bit under 3 gallons.
jyoutz
Jan 14, 2019
3,624
2,718
Edgewood, New Mexico
Do they have the same motor?
11,757
No. The MX6000 has a four cylinder 2.4L engine and the M6060 has a four cylinder 3.3L engine.
nbryan
Jan 3, 2019
1,425
944
Hadashville, Manitoba, Canada
Average about 1/2 gallon per hour. The 5 gallon tank can get from around 8 to 16 hours depending on job.
Front mount snow blower with heavy snowfall clearing eats the most fuel/hour.
No complaints!
jyoutz
Jan 14, 2019
3,624
2,718
I must have gotten it confused with the L6060. I believe the MX and the L share the same engine.
