Wipers, radio, heater not working?
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,542
2,007
Western MT
Probably a fuse.
Mine don't work either, but I don't have a cab. :D
8,538
Lost power to my radio, the heater, and wipers? What's wrong with my tractor?
Really? :confused:
You think you could give us any less information to go on? :unsure:
I think we can all play this guessing game. :rolleyes:
5,591
Always best to post make/model of your tractor/options.
By the sound of it, you have a cab and everything is part of the cab , if so, what make is it, dealer installed, how old ...any modifications...
To have all three units fail door #1, no +12 power or door #2, open ground. Door #3 BOTH power and ground feeds have been severed.
8,538
I was driving along when wipers stopped. Radio shut off and the heater. I checked fuses and they are good. I'm guessing a bad ground some where? Locations of that would be helpful.
Come on...
We couldn't possibly guess at what model you are dealing with!
We couldn't possibly tell you anything about where any wiring might be or not be!
Why don't you tell us what model you have.
8,538
Sorry, My Carnac the Magnificent hat is at the cleaners.
5,591
Sigh, I try to help anyone with 'electrical' problems and it's in my 'wheelhouse ' and easy for me but honestly without knowing which tractor and cab, I can't lookup wiring diagrams or drawings to pinpoint WHAT is causing the open and WHERE it is.
Given the that info it could take less than 5 minutes to SOLVE your 'no power to stuff' problem. I know it'll take less time than my 2 1/2 finger typing of this reply !
CRidgeway
Kubota KX 040-4, LA525
Feb 1, 2025
Wenatchee WA
I just bought a used 220 hr 2022 Kubota KX040-4 full cab with AC... I'm having the same problem. Everything works except the heater, wipers, and radio won't turn. Fuses look fine.
Cigarette lighter also has no power
I figured it out. There were loose wires under the heater control panel. removed the heater panel 2 screws and jiggled wires.
5,591
'jiggling' the wires doesn't FIX the problem ! Pretty sure tractors vibrate a bit, so 'oospy, lost it all again'.....
Really need to inspect,tighten and secure all connections before closing it back up.
