CNC Plasma table mods.
3,716
Well my table finally started leaking this weekend, so it is time do something about it.
Its kind of a "known problem" cause they ship the tables in 2 pieces (to save money most likely)
It wasn’t too bad, but I figure that it ain’t gonna get better, so I figure I may as well try to TIG her up.
So first I have to drain the table…but the factory plugs are frozen in place and I end up ripping the gaskets during removal.
Well F’it I guess, I will just have to convert my table to a new drain system, just I like I planned to do 4 months ago…But ya’ll know how it is, projects start to stack up as priorities change…blah…blah…blah…
I decide to copy a guys idea from the Lanmuir site (giving credt to @nortonscustoms for the idea) but I am kinda short of the proper material, so I start scrounging through the scrap pile and I find a few possible candidates.
I first find this square piece of “mystery metal” and some A36 round stock that might work.
I am worried that the pressure from the squeezing action will bend/warp the square piece, but that is the biggest/thickest piece of scrap steel I have laying around, so I find this “roached out” circular scrap of aluminum as a candidate for a “backer”.
IMG_3299
IMG_32991920×2560 381 KB
Off to the lathe we go.
I decide to cut off the corners on the band saw to get a “round’ish” shape and will try to make it round on the lathe after I get it to what I consider the proper depth.
IMG_3303
IMG_33031920×2560 531 KB
Now keep in mind, I am doing this off a “bar napkin” drawing and I have no idea if it will work.
Then I start “whittling away” at the A36 with my new “carbide inserts” that I am trying out.
They work pretty good so far.
(However one complaint is that I can't get the inserts to make actual "chips". Instead I get long strings that eventually get wrapped around the chuck and scare the sh!t out of me when they catch........But thats a different topic entirely....)
IMG_3301
IMG_33011920×2560 414 KB
Now it’s time to chuck up the “backer piece” to clean it up and carve out a “recess” to make enough room for the die.
IMG_3304
IMG_33041920×2560 382 KB
In the end, I end up with the “finished product”
IMG_3334
IMG_33341920×2560 226 KB
IMG_3335
IMG_33351920×2560 281 KB
Now to cut the holes in the table.
I can’t find my “hole saw” set, so I think they must be up at the cabin. Hmmmmm…
I decide to use the Langmiur to perform surgery on itself.
After removing the “slats” I lowered the torch head to and only used the bottom clamp to secure it.
I figure 2 quick cuts and it should be fine.
So I mark the original height first with a marker, and lower the torch and only use the lower bracket to hold it for these 2 cuts.
IMG_3307
IMG_33071920×2560 356 KB
The tables is “nastier” than I expected,
IMG_3308
IMG_33081920×2560 589 KB
Then I decide that I should clean the area off to maximize my chance for a “successful first cut in SS”. I am also not sure how that water will effect the cut quality, so I spend some time with about a “Sherwood Forrest” worth of paper towel and a scraper, to try and “sop up” some of the slop.
IMG_3310
IMG_33101920×2560 599 KB
3,716
Well my “guesstimate” settings were not perfect, but it did a “good nuff” job.
IMG_3312
IMG_33121920×2560 513 KB
A few taps with a hammer and bingo.
IMG_3313
IMG_33131920×2560 457 KB
IMG_3315
IMG_33151920×2560 337 KB
IMG_3319
IMG_33191920×2560 163 KB
Now off to the TIG machine to try and weld up this table without warping the hell out of it.
In the past my success rate of welding “sheet metal” without warping has not been good, but sometime you just gotta keep trying. So I decide to just “stitch it together” with a series of 1 to 2 inch welds, trying to keep it “cool” as I go.
Well I must have forgot to take pics as I went along, but I “stitched it together” with “mild success” (?).
I did have to “beat it into shape” a little but I am hoping it will work.
So now I start to use the die set.
As I am cranking on it, this “bad feeling” overcomes me…I think that the tolerance of my die could be too tight, and it might end up accidently being a “punch out die” instead.
So I throw it back on the lathe and make it tapered a “wee bit”.
IMG_3337
IMG_33371920×2560 658 KB
Ahhhhhh…that makes me feel better.
IMG_3336
IMG_33361920×2560 448 KB
Well I am clearly not nearly as strong as i used to be, I have to enlist the help of my impact gun to squeeze them together, but it seems to have worked.
IMG_3338
IMG_33381920×2560 443 KB
IMG_3339
IMG_33391920×2560 333 KB
3,716
It appears as though my welds and the drains were a success!
I filled the table ~72 hours ago and they are leak free.
Here is the finished product and some close ups of the finished drain install/
IMG_3349
IMG_33491920×1440 225 KB
IMG_3344 2
IMG_3344 21920×1440 471 KB
IMG_3343 2
IMG_3343 21920×2560 582 KB
The welds are not “professional quality”, however for a layman, all I can say is that, at least they hold water.
The stopping and starting of a weld has always been my Achilles Heel, and warping was a real problem for sure.
It appears that my die set up leaves a slightly larger “circle” and wider impression than the original “dimple die does”, but it worked very well.
IMG_3348 2
IMG_3348 21920×2556 341 KB
You can see my "stops and starts" are very prominent here. I just can't ever figure out how to make it look like one continuous bead.....Oh well.....It holds water, and thankfully/hopefully will never be seen again.
IMG_3346 2
IMG_3346 21920×2556 330 KB
Fot anyone that might be interested, I will post the name of the drain I used later today, but I imagine that there are many manufacturers that will work.
:beers:
another shot of my crappy welding.
IMG_3346 2
Moen 22174 Sink Basket Strainer with Drain Assembly, 2", Stainless Steel
and here is a link.
https://www.amazon.com/gp/product/B000TFDY0E/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1
Just for future reference, I programmed a 2 inch hole to be cut in the table.
I did have to use a file a “wee-bit”, (like for 10 seconds) but after that, the die fit very nicely.
I also ‘dabbed’ a little wheel bearing grease on the threads of the die to prevent galling while using the "impact gun’ to tighten it down.
On a side note: Holy sh!t this thing drains fast now!!! That 1 1/2" PVC made short work of draining the table.
I filled a 5 gallon bucket in less than 10 seconds
:+1:
3,716
Here is a few more shots of it.
This is how it looks when assembled
Here is where I had to carve out that recess on the "backer plate" (on the left) so that the die could "poke through" a little and make the "dimple.
Hugo Habicht
G1900
Jun 24, 2024
687
898
Ireland
Now this lathe looks very familiar to me... :)
Btw: length of the chips depends a lot on the material.
Very nice job with the drains and also welding the two pieces together (y)
p.s.: I think it would be a good idea getting a cover over the lead screw ...
Yooper
3901 LA525
May 31, 2015
1,647
791
NE Wisconsin
Nice work! Making the dimple must have been very satisfying seeing the outcome. What filler rod did you use on the stainless?
InTheWoods
B7510/FEL, B7100D, ZD18, ASK-R130
Nov 17, 2023
244
191
Indiana
A friend of mine ditched the water-filled table and now has a downdraft vac system - he's super happy with it - no more splashing and steam.
Sidekick
Jul 29, 2023
1,012
1,367
N.Y,
3,716
Yes it was pretty cool to see it actually work.
I used ER308l for filler. It seems like a pretty generic filler for stainless.
3,716
So far I am loving that lathe!
I thought that because the insert has a chip-breaker built into it, it would do a much better job than what I have experienced so far. I'll keep messing around with speeds and feeds I guess.
3,099
Some materials will always produce a long, stringy chip.
Most of the time when a chip breaker insert is not breaking the chip, it is because the cut is not fast enough, or heavy enough, or both.
Chip breakers were initially developed to speed production times. (less fooling around with long chips)
That is fine if you are hogging huge amounts of material from a large piece in a large rigid machine, but it is sometimes hard to do that on home shop projects.
(Abom79 does a lot of hogging on big stuff)
I used to run a production job on a part that the methods department said could not get hot, and had set speeds, feeds, and depth of cut under full flow coolant.
It was a cast 17-4 PH alloyed with monel, and that job produced the longest, most deadly razor sharp, vicious chips imaginable.
We finally settled on pulling the chips off the machine as they were produced with chainmail gloves and two large needle nose pliers. We tried to guide the chips into a loose pile on the floor.
God help you if they caught & balled up around the part or spindle.
I once had a chip grab and wind up, and as it passed my calf, it sliced through my levis & into my leg.
Nasty stuff.
3,716
Nasty stuff.
That is good to know sir!
I will try some different speeds and feeds on the common a36 an see if I can get some nice chips.
