Pressure reading
aftershock
L5450, KX91-3
Jan 31, 2025
ontario, Canada
I have a 22+ year old L5450 I suspect the hydraulic pump is failing. I am putting together a pressure gauge to plug into the rear remote. Does anyone know what I should read on a healthy pump and a number where I should look at replacing? TIA.
10,379
The pump might be fine and your pressure issue could be from the pressure relief valve not working properly.
You're looking for 2400PSI - 2500PSI
FYI, it's a 33 year old tractor. šŸ˜‰
rbargeron
Jul 6, 2015
1,183
260
western ma
I've been a little lax lately in following L5450 questions. Here's a page from the WSM. The relief setting is around 2600-2700 psi. If your pump is still above 2000 its still capable of doing a lot of work.
