Kubota Rotary Tiller FL1000 ASSY JOINT UNIVERSAL length.
Tractor J
Kubota B7200D
Jan 27, 2025
29
I have a Kubota Tractor B7200D with a Kubota Rotary Tiller FL1000. The manual show a ASSY JOINT UNIVERSAL 70798-0041-1 (70710-6130-1) bring to find the Min and Max length. I'm thinking about adding a Pat's Quick Hitch Cat 1. Which means it will add about 3-1/2" to 4". Will I need to buy a new shaft? Thanks
8,793
If you have it in front of you, pull the shaft out 4" and mark then pull out the rest of the way and tell us what that length is.
Tractor J
Kubota B7200D
Jan 27, 2025
29
I do not have it here, but I will do that. This was in the family and I have it know and bring to learn more about it before buy a Pat's quick hitch. Thank You for your help. john
8,793
One other option is to add a PTO extension to make up for the hitch.
I add a quick hitches to my B and L and I didn't have any issues with my PTO shaft lengths.
Donystoy
Dec 10, 2013
667
302
Binbrook, Ontario
An extension would certainly be the simplest solution. I had to add one to mine to be able to install a PTO pump. I think it added about 4 inches to the length. The only issue is that it adds a bit more slop in the driveline as they have a small amount of play.
When I am hooking up a driveline for the first time, I will have it so that it retracts "just enough" to attach it when the implement is raised, and the shaft is perfectly level. Also retaining suitable overlap.
