Starts But Stops after 2 Seconds Everytime Now
7,375
You have a stop solenoid feed issue.
Is this right?
It cranks starts and as soon as /or within seconds of letting off the key from crank it dies.
Say you replaced the stop relay, is a little odd because it shouldn't have one.
There are two power feeds and a ground that go to the stop solenoid.
#1 feed is the White from the starter, this is the pull in signal.
#2 feed is the Red / Black this is the hold signal.
Black is ground.
The fact that you say when you wiggle the key the lights flicker is pointing to a bad switch or wiring connection.
With a simple test light put it on the red back at the solenoid, if the light flickers or does not stay lit with the key in run, you will need to chase the issue down.
Yellow is crank signal, blue is hold signal.
Steve/Jonny and Mike - - -
I'm so glad @North Idaho Wolfman posted this.
@Russell King was heading that direction also.
Key switches are known to go bad. A tractor of that vintage is also prone to some bad connections.
Betting a $7 test light will serve you well.......and I'm not good at electrical stuff at all.
Good luck! ;)
jonny5757
1998 Kubota B2100 Tractor
Jan 24, 2025
30
Hemet CA
well so far i have changed the stop solenoid, changed the fueses, new ingition switch, battery is good, new air filter and fuel filter, and new fuel, and it slill starts but wont run. i have a new fuel pump to put on next, need help
11,314
You need to read Post #18 and test that accordingly.
You are not getting hold power to the solenoid.
Remove the solenoid off the tractor and start that tractor, does it run?
jonny5757
Jan 24, 2025
30
Hemet CA
thanks for all the help, i got the tractor to run, i took the stop solenoid out and it started and ran but it would not shut off so i move the lever by the end of the throttle rod end, it shut off the motor, i guess i have a bad connection.
mendonsy
B7500HST/LA302
May 28, 2012
363
38
Mendon, NY
It is stories like this one that make me really glad that my b7500 does not have a fuel solenoid, just a manual push-pull shutoff.
jonny5757
Jan 24, 2025
30
Hemet CA
i have changed every thing i can think of, fuel lines, all filters, starter switch, oil, all fues, fuel lift pump, emptied the fuel tank, cleaned the fuel on off valve, good battier, new fuel cut off solenoid . runs good when it runs
3,166
Please list what you have done or replaced since we can’t know what you can think of. Otherwise you will get a lot of recommendations to replace the stop/run solenoid or to make sure you have 12 volts on some wires when running or when cranking.
jonny5757
Jan 24, 2025
30
Hemet CA
well you'll have to post WHICH tractor you have. Can't offer what is causing the problem until I have a look at the wiring diagram.
Obvious things are 'user upgrades ' to electrical, vermin chewing wires, loose connectors, bad battery cables, corroded wires, gimpy switches(seat,PTO, PBrake, ?? )
Sounds like there might be some crud in the fuel tank. Check the fuel line from the tank to the filter to see if you have full flow.
Mike-B2100
1998 Kubota B2100 and other junk over the years
Jan 26, 2025
Winthrop WA
Well as it turned out, it was the stop solenoid/control wiring. Fix was to just cover the hole (actually ground off the nub) and used the manual lever via an pull wire to put it back in operation.
Poor form for me, I should have responded sooner, appreciate all the help and getting to the root of the issue.
-- Mike
jonny5757
Jan 24, 2025
30
Hemet CA
-- Mike
i did that, should i leave it unplug too
jonny5757
Jan 24, 2025
30
Hemet CA
i put a list of things ive done so far above
11,314
is it hard to replace the wiring harness on a 98 b2100 kubota
We don't need 2 threads on this.
You have an electrical issue that you need to figure out.
Get a test light and start following the wires as I pointed out in post #18
jonny5757
Jan 24, 2025
30
Hemet CA
Your profile says 1998 Kubota, but nothing else.
If you told us what Kubota you're working with, it would be helpful.
Is it a tractor, excavator, UTV, skid steer?????
What model?
Starts but doesn't run - - does it shut down when releasing the key?
no
