Does tire grooving really work?
ayak
L3301 HST
Feb 16, 2018
759
1,201
WV
Works especially well in wet/packed snow.
je1279
Dec 6, 2020
828
585
Upstate NY
Hmm, anyone KNOW if they're better on pavement than the the 'industrial' type that came on my BX23S ?
The R14's have a center lug that makes riding on pavement more enjoyable than on R4's.
11,692
When it's time to replace the tires on the MX I'll be looking at R14s for sure, assuming that they're still around. I took some design cues from the R14 tire when I grooved the MX R4 tires. The grooved lug is better able to mold itself to the terrain compared to a solid lug.
5,179
How long did it take to cut the groves in the lugs like you did ?
L35
Jun 13, 2010
694
805
CT
I need some grooves in my life. R4 on snow stink.
11,692
If you're asking me probably three to four hours for all four tires, but I did it in stages.
pokey1416
Jun 24, 2020
572
884
SW Michigan
The only advantage I have heard of R4 over R14 is wear and sidewall strength. I haven't confirmed this but I have spent considerable time on construction sites and have yet to suffer a flat (probably just jinxed myself). When I got my tractor in early summer 2020 the dealer told me they didn't have R14 tires yet available for the Grand L 60 series, I don't know if that has changed by now?
4,081
2,777
Check with your Ag tire suppliers instead of the tractor dealers
Orange man
Kubota L2502 LA526 loader , woods prd6000 mower, Land pride RB 1672
Jul 23, 2014
258
169
WNY
When it's time to replace the tires on the MX I'll be looking around. I took some design cues from the R14 tire when I grooved the MX R4 tires. The grooved lug is better able to mold itself to the terrain compared to a solid lug.
The tires in the top picture are not r14, they are the new r4 tires.
11,692
Oops .... here's the R14 tread pattern. Sorry about that. :giggle: I grabbed this image from an online tire retailer so assume that it's correct.
imarobot
5740HSTC-3, FDR2584 Finish Mower, BH92 Backhoe, L2195A Snowblower, LA854 FEL, +
Apr 18, 2025
373
284
NH
Looking to buy a tire groover. Is the Ideal Grooving Tool good? It's one of cheapest & simple type I found but only 250W. Most others are 350-1000W. Does the Ideal generate enough heat to easily groove tires?
Or if anyone could recommend other better brands I'm all ears!
7,514
I think mine is 250W, and it worked fine. I'll double check that when I can. The rate you push the tool and the sharpness of the blade determines the ease of the cut. When the sun is shining on a hot day makes quicker/easier work then in an ice storm! ;);)
I have grooved a few tires and still on the original blade. It is the Ideal groover.
old and tired
1,919
1,297
Works fine as long as you are not in sub-freezing temps! For the price, 250w is just fine... I would buy the better ones, if I were setting up a business, grooving tires...
I touched up mine last year and will need new tires within a couple years... so it's not something you'll be using a lot.
Spam Bot
Windows Computer
Aug 3, 2024
174
129
Austin, Minnesota/Key West FL
I bought a tire groover last spring, and over the summer, it got lost in the garage. If you see it, please let me know where it is. I need to groove my tires so I can move more snow more easily. :unsure:
10,697
It's over there, under that stack of stuff.
