Kubota L345Dt Starting problem
Geirrh
Kubota L345DT
Jan 17, 2025
Tana, Norway
Hello
I have a L345Dt and it will not start anymore. When i try to start, it glows, but when i try to engage the starter it blacks out. Then i have to wait a few minutes before i can try again. it goes all black exept accessories like lights, they work as normal. Im not sure if if the starter solenoid engages. Just put in a new battery (new used) i have a feeling that it is not good, and the starter don´t get the amp it needs, but before i get a new one, i try here if anybody have had this trouble before.
Thanx in advance
Geir-Rune Hansen
TANA, NORWAY
2,930
Assuming that it cranked before the new battery was installed.
Forutsatt at det sveiv før det nye batteriet ble installert.
Does the new battery work in another vehicle?
Fungerer det nye batteriet i et annet kjøretøy?
Does another battery make the tractor crank?
Får et annet batteri traktoren til å sveive?
Have you used jumper cables with another battery? If so, how was the jumper cables attached to the tractor?
Har du brukt startkabler med et annet batteri? I så fall, hvordan var startkablene festet til traktoren?
If your tractor is wired like original, the crank position is trying to power both the starter and the glow plugs at the same time, so worst condition for the battery. It will probably require a new large Cold Cranking Amp battery and new cables to be installed, that is the usual solution.
Hvis traktoren din er kablet som original, prøver veivposisjonen å drive både starteren og glødepluggene samtidig, så dårligste tilstand for batteriet. Det vil nok kreve et nytt stort Cold Cranking Amp-batteri og nye kabler som skal installeres, det er den vanlige løsningen.
Geirrh
Kubota L345DT
Jan 17, 2025
Tana, Norway
Thanks for early replies! :)
the Ground cable from battery to the frame is new. But the rest is original i assume. I have plans to rewire the whole traktor, but i had a hope that i could wait until the summer because of the high frequent need of the traktor and snowblower in the winter.
To answer the other questions i have tried With jumpercables from my car With no luck. As far as i remember the battery is 75 amh and 660 Cca, so if that is in good working condition it should be suffient.
Well, my best hope is to get it started once so i can get it to my heated garage for further troubleshooting, i don’t want to be outside in -25 degrees celcius / -13 degrees farenheit.
Thx again
Geir-Rune Hansen
10,677
Thx again
Geir-Rune Hansen
Make 100% sure the tractor is in neutral and that the stop lever is not engaged.
Set the parking brake, turn the key to run.
Go to the starter and jump from the battery terminal on the starter to the starter solenoid terminal (small wire).
This should get the tractor to crank and run for you.
2,930
If you need a wiring diagram there is one in post #27 in this thread
bhaack
L305DT
Jan 17, 2025
15
Kansas
I'm going to venture a guess that the switch plate inside that nippendenso solenoid is pitted where the copper contacts hit it. If you pull the 3 screws out of the triangle shaped cover that plate will fall out along with its return spring. The contact lugs can be seen inside. Clean that plate with something like a wire brush or emery cloth, reassemble it and try it.
6,246
if the cable between the tractor battery to starter is 'bad' ,then jumpering a good battery to the tractor battery won't do anything as the cable is 'bad', won't pass current through it.
