Grapple options for the L2501/LA525
nerwin
Z452KWTi-60, L2501, LA525, HLA Forks, Land Pride STB1072
Nov 13, 2024
647
1,870
Vermont
youtube.com
I have yet to hear anyone say they have a grapple and wished they had a different style or think they made a mistake putting the money into a grapple. Maybe that’s partly confirmation bias, but I don’t think that explains a total lack of expressed regret. Point being, you’re unlikely to regret whatever you get so long as you don’t get some giant thing that sucks up all your lift capacity.
Personally, I’m partial to twin lid long bottom, probably because that’s what I have and I like it… very much. View attachment 146448
Dang that's quite a log. Must be like 30+ inches round.
X-Pup
L2501, 526 Loader W/QC LP RCF2060 Cutter, BB 1260-82, 3RD Function, top&Tilt
Nov 13, 2022
47
54
Washington
I've been researching grapples for my new L2501 for a few months now. Cost versus performance dual lid folks seemed to like the MTL.
https://www.mtlattachments.com/tractor-attachments/new-compact-vertical-root-grapple
Personally I've got my eye on the Precision manufacturing dual lid Big Mouth 322.
https://www.agfolks.com/product/big...ble-grapples-john-deere-quick-attach-brackets
Right now, I still have more time than money.
I just posted the first links that came up. They both come with the skid Steer connect option.
I realize the Precision unit is much more expensive. I usually get what I want and cry once. :)
nerwin
Nov 13, 2024
647
1,870
Vermont
youtube.com
Yeah I have a Big Mouth! 😉
Almost worth buying just to say that.
MOOTS
MX6000
Jun 27, 2019
2,234
2,850
Canton, Georgia
That big mouth looks interesting. Root rake style yet dual lids. Wonder how that would actually hold up in real world use?
11,757
That grapple looks under-built to me, and the cylinders being positioned where they are seems odd for a double lid design.
X-Pup
Nov 13, 2022
47
54
Washington
I had the same impression. 1/4inch plate seems a little thin to me, even if it is AR400. It's like a big skeleton but it seems solid. There are a couple of videos of Tractor Time with Tim giving it a workout. It looks pretty solid in action. He said he noticed a little flex in the middle of the top lids if you grab something that isn't long enough to reach the outer edges, but it doesn't deform and returns to its original shape.
Also, keeping the cylinders in a protected location behind the grapple required locating them outside the skid steer connection. Possibly a compromise as opposed to locating them on the top of the lids.
I also think the larger size of the opening also results in a weaker grip force.
All things considered - I still like this one.
I also like the wicked 55 with the exception of not having a center hinge like the 60.
4,038
2,488
I like the pivot design on the Precision. Many lesser grapples just use a bolt and tabs, that design is cheaper but doesn't give much bearing area.
Outback101
LX4020HSD ROPS, RCF2060, PFL1242, LA545 w/60"
Feb 1, 2025
10
Northeast Iowa
I'm looking at Stinger attachments that are made relatively local to me. Heavily considering the 66" size. Like the weight and design.
They have several styles available. Check out the offerings under both skid steer and compact tractors.
Appreciate the Messick's video's (y) That was something I had not considered as a problem/threat to my hydraulics.
TBK
L2501
Apr 23, 2025
Did you ever decide upon which to get and if you did, do you like it?
I am looking into grapplers for my L2501. I was thinking about buying the EA 55" root grappler but with their recent issues I've opted to look elsewhere. Currently I'm looking at a few different ones and build materials and weight are two extreme considerations for me as I am doing a lot of brush/dead tree cleanup along with picking up BIG rocks. I like the idea of dual jaws because of the various size loads but then I need to think about longevity with the material type.
The Stinger looks really nice, the structure seems to be strong and supportive, has two jaws, and also has a plate along the back which protects from stuff poking into the radiator but it is only made from 1/4" AR200. Would it stand up to rock moving punishment?
https://stingerattachments.com/buy/ccg-56-compact-clam-grapple/
The Catawba looks really nice and has similar okay reinforcements, looking like the EA Wicked 55. It is missing gussets on the tines compared to the Stinger but is a better steel w/the Hardox 450 and it does have a center pivot. However, it has a single jaw.
https://cattachments.com/product/ca...achment-for-tractor-with-high-strength-steel/
The Homestead looks okay but doesn't seem to have the same level of reinforcements. I know it is thicker steel but is that enough to offset the need for the webbing/gussets? It is a single jaw with no center pivot point and I am concerned about twisting.
https://www.homesteadimplements.com/pinnacle-series-root-grapple
The MTL CV- 60" Quick Attach Black has dual jaws but unknown steel type, weighs a LOT at 396lbs, and it is currently out of stock.
Precision Manufacturing (AKA - AG Folks) Mini 322 has a lot of features I like, twin jaws, only weighs 265lbs and uses AR400 but the cost is almost $4,000 with taxes and shipping.
https://www.agfolks.com/product/big-mouth-mini-322-grapple-rake-double-grapples-skid-steer-brackets
Sidekick
Jul 29, 2023
1,292
1,887
N.Y,
The Catawba root grapples are actually Hardox 500 now.
The Evil Twin
L2501, LA526,
Jul 19, 2022
3,214
3,564
I (personally) would lean to the Cat unit.
OntheRidge
Nov 1, 2020
504
591
Homestead just came out with a dual lid unit. I have the single lid and am very happy with the quality of construction.
AOW162435
'25 LX2620 / '79 B7100 / '03 JD x595
Jun 16, 2023
199
116
Ellicott City, MD
Actually it's Eddie's welding that is the founder of Catawba Attachments. A business that has really supported the local veterans. Nothing to do with EA or their poor customer service. I love my Catawba 55 grapple and got it in 3 days from ordering. Contact Cody to get educated on their history.
I recently ordered an EA Wicked Light 55" grapple for my LX2620. The ordering process was painless, any questions I had were answered over the phone, and the grapple shipped in under 4 weeks. I think I initially paid a 10% deposit to get in the build queue. Absolutely zero complaints with the process or the product.
For compact storage, I fabricated a kickstand for it.
Andreas
Reactions: 6 users
BBFarmer
Jul 12, 2024
789
1,621
Terry, MS
My neighbor just put a titan root grapple on my old 3301 (525 loader).
Not sure the size, but when I was up cutting at the road last week i saw it behind his house, and it looked absolutely massive on her.
I would think between the weight of that grapple and the ssqa, he may have possibly cut his lifting capacity right in half LOL. It does look awesome though.
TBK
L2501
Apr 23, 2025
Weight is indeed one of my biggest concerns which is tough to juggle w/wanting dual jaws. I've run singles before and they do okay for 'evenly' grown trees but as soon as you get something that is odd shaped they have a tendency to twist and even drop the load. I appreciate all of the recommendations/help for a noobie to the forum!
I really like the Stinger but that AR200 just sounds too weak for the rocks I know I will be carrying/moving. Perhaps Precision Manufacturing has a distribution location in Texas....that would make the shipping cost go away as i could drive and pick it up.
Anyway, thanks for the continued discussion, it's actually helping.
11,757
It's hard to believe there's no connection when so many of their implements appear to be cloned from EA implements. And then there's the name thing with the Catawba Rake Grapple 55, 60 and 66 which EA has called the Wicked 55, 60 and 66 for years. The only company that calls a land plane/grading scraper a land leveler is EA, and yet Catawba's recent creation uses the same name for theirs. Even the paint is the same yellow. All indicative of something. Maybe Catawba found a bunch of engineering drawings in a dumpster out back behind the 1506 Emmanuel Church Rd, Conover facility when things weren't going well for EA. :unsure: Afterall, it is only 20 miles from Catawba to EA.
Someone knows the truth in all this, but it sure isn't someone on this forum.
jyoutz
Jan 14, 2019
3,628
2,728
Edgewood, New Mexico
EA 2.0 under a new name.
