Kubota BX instrument cluster replacement
stevenrb718
Pennsylvania, USA
Does anybody happen to have a replacement instrument cluster for the Kubota BX? I've had no success repairing mine without a schematic and I'm not looking to pay $400 for a new one.
6,319
curious as to what's wrong/ what's right with it
which 'BX' ?
I have a BX23S.... K287162502 ... is over $700 CDN FYI.
also in 'electrical' sub forum, #13 post has clear wiring diagram !
stevenrb718
Pennsylvania, USA
which 'BX' ?
I have a BX1870. The entire cluster went out awhile back, except for the turn signal indicators. I've opened it up and found a fair amount of surface corrosion, but nothing crazy. I repaired a few traces and a couple vias with no change. I know they're terrible with their water sealing and I think there may have even been a recall on them. I couldn't find a schematic anywhere, so I'll have to see if that diagram helps.
3,753
2,167
What model is your BX????????
The different series BX have different clusters.
Mountainman
L2501, B7100, B2710 B21, B1750, B2400, B7200
Jul 10, 2022
443
182
Attalla Alabama
mossycreekoutdoors.com
Finding used BX clusters from the 50 series and newer that still work is hard. They've had some recalls and come out with newer versions but hasn't really improved much. There are 2 different versions thatll work on the 50 60 and 70 series but they also have different connectors. Technically the 80 series will work also but takes some fab work and making your own connector
Mowbizz
Bx25d
Aug 19, 2021
626
357
Years ago when I had my BX25D in for some service, they replaced mine under warranty because of moisture inside the display…they put a label on with the hours at that time. Now years later, the display is filled with moisture again but still works.🤔
6,319
Please post a few good pictures ,both sides of course.Having designed/built PCBs for decades, my eyes might see something your have missed. The usual suspect areas are between traces at connectors, under DIP packages, Zebra connectors.
When powered does the LCD function ? gauges 'self test' ?
stevenrb718
Pennsylvania, USA
I'll get some pictures next week. I've rebuilt the damaged traces that I can find, and reflowed the ICs. Nothing functions except for the turn signal LEDs. I'm getting various voltages at the wiring harness, but without a schematic, I don't know what voltages should be where. I've checked for heat with a thermal cam, but nothing seems apparent.
3,753
2,167
Without the model number of your tractor, you are unlikely to get a schematic.
6,319
It'll be a 'custom' chip, preprogrammed specifically for that 'configuration' of sensors and operating conditions. so 'CPU' won't be 'off the shelf'.
Should be able to do several 'on the bench tests' though.
both fuel and temp are analog inputs, so +12 should 'full scale' the gauge
+12 on back light pin, should 'back light' the dash
grounding oil pressure ,should turn off oil press LED...
A good clear picture of the 'CPU' chip would be nice.Hopefully has mfr number on it NOT Kubota part number.
See if there's a crystal close to it with 2 caps.
Check for any fuses in the power supply section.
+12 will get converted to +5 or +3 'somewhere', usually a 3 legged device.Kinda obvious
See IF you get +5 anywhere....
This in one of those 'be nice to be there to see' to help, but pictures would be nice for 'remote help' !
While I don't any experience with injector pump rebuilds' I have 10s of 1,000s of hours (6 decades) of design/build electronics, last 3 decades programming PICs to do all sorts of stuff.
Good news for you..NO CANbus port, so really a simple, old skool design/build.
mtfalk64
BX1870
Apr 5, 2025
Maine
I have 2013 BX1870 bought used. moisture keeps getting under the glass of instrument Cluster. you may find that the moisture is your issue. also because Kubota did a terrible job on these the connector and pins on the back seems to get corroded. mine unfortunately broke off and my techometer doesnt work now. planning on replacing the connector with a wire harness that I will solder wires where the pins come out of the back of the instrument cluster. Pretty sad that Kubota charges so much for their machines and this is an ON GOING ISSUE.
mtfalk64
BX1870
Apr 5, 2025
Maine
Sawdust&Shavings
Apr 25, 2023
222
265
Stafford, VA
I keep my BX1870 out in the elements year around; to keep moisture from getting into my instrument cluster I use a 3’ x 6’ tarp…see pictures:
pablo9
Chicago, IL
hello,
I'm also interested if anybody found a solution to this?
I have a BX24D with broken LCD hour meter. It was working just fine and suddenly started flickering.
I wonder if I could find just the small LCD screen and replace it. I already disassembled the unit to check for some part# of the components but didn't see anything printed on the LCD screen.
I believe it's a standard small LCD hour meter that is commonly used in various gauges for industrial, marine equipment.
I'm posting some images. Hopefully someone already figured out the fix for this or can point me the right direction.
