Excellent, exactly what I was looking for. Thank you for taking the time to detail out.Ok the Mast connection bars are 2inch wide 1/2 inch thick and 43 5/8 inch long with a tab welded on the end and 3/4 inch holes slightly off center. Also a drawing that is NTS and pretty rough.
I have attached a picture and also a picture of where they are stored.
And a couple pictures out of the operators manual. This shows how to use them and where to install the L-bolt.
Let me know if this is enough info or you need more.
Ii also still have stands if you need that info also, for some reason they have a bend that is not from the factory.
Do you know where the stands for storage at the back coming out of the bottom are stored in the loader? I don’t see them anywhere on the loader.Excellent, exactly what I was looking for. Thank you for taking the time to detail out.
On the inside of the loader arms.W
I’d appreciate that - I don’t see those anywhere on the loader. Just some pictures and basic measurements would be good and a picture of where they are stowed so I understand those constraints as well in building these.Like Wolfman says they are on the loader arm.
Mine ore on the left side. Opposite side of the controls and hoses.
If you want I can get some measurement's on them also.
Thank you very much! Should be pretty easy to make.The stand is 5/8 inch square stock 32 1/4 long and 11 1/2 reach in with a 1/4 for the hsir pin retainer clip.
The gusset is 1 1/2 x 7 x1/4.
I did not measure or include the bent pin that is hangs on on the loader frame.
As you can tell mine are bent, I have not removed from there location until now. I had bought this in 1996, so was bent prior to that.
See attached.
Glad to help out. Good luck on getting them made,Thank you very much! Should be pretty easy to make.
I finally made the pieces and detached the loader. Just need to prime and paint orange. Here’s some photos. Appreciate the help! If anyone needs these made let me know!Thank you very much! Should be pretty easy to make.
