BH92 Backhoe Dolly
Brandonorr55
L3800
Aug 18, 2013
39
10
Missouri
Finally got around to making a dolly for my BH92 backhoe. I couldn't find any plans online, so I bought a few sticks of 2" x 2" tubing, and used some scrap around the shop to make my own. It rolls around the shop extremely easily and is very sturdy. I'm not a professional welder, so don't look too closely!
Reactions: 6 users
jkrubi12
Sep 24, 2012
403
302
right coast
Nice pics, nice BH, GREAT design & construction. Gonna paint it? Never seen 'double dollies' like yours👍
Brandonorr55
L3800
Aug 18, 2013
39
10
Missouri
Thanks! The double caster wheels are super heavy duty and help it turn very easily. I'll probably throw a quick coat of paint on this summer.
bird dogger
Feb 24, 2019
1,795
1,769
North Dakota
Paint ?? :LOL: Your design is very similar to the one I built for my BH77 a few years ago. It still needs a clean up for a paint job!!
You can see my build Here I have my BH resting at an angle on a stand so that I can easily roll it right up to the tractor and over the mounting hooks without needing to first hook up hydraulics to use the outriggers to lift the hoe up to proper height. For removing the hoe, you do need to use the outriggers, of course.
There's also a couple of stops on the stand that help locate and keep the hoe in place when install/remove operations are being performed.
Brandonorr55
L3800
Aug 18, 2013
39
10
Missouri
Our designs look very similar. I like the alignment posts, and angling the rear portion to slide the bottom pegs into the hooks, Thanks for the ideas!
5,311
You sir, get an A+ for being "Heavy Duty".
Looks great BTW!
Grandad4
Apr 5, 2016
433
186
Greensboro, NC
Very nice setup for that BH92! Those are heavy backhoes, approaching 2,000 lbs for the hoe and the subframe. Talk about rear ballast! Mine - an older model, but similar - sat on cribbing timbers when not in use. Never liked that but didn't have the imagination to build what you did. Very cool!
Brandonorr55
L3800
Aug 18, 2013
39
10
Missouri
Your dolly looks great! I have gone back and forth about the alignment posts, and think I may add some on mine too. I like the idea of your pins sitting up high enough to steer it into place without use of the outriggers. This one sits considerably higher than my previous tractor with BH77, but I may see of it is doable. Awesome work!
pokey1416
Jun 24, 2020
572
885
SW Michigan
Very nice. If you ever decide to make more and sell them PM me.
bird dogger
Feb 24, 2019
1,795
1,769
North Dakota
Your wheel base on your dolly is quite a bit wider than mine. Even with yours sitting up a little higher..... it shouldn't be a problem. You can always undo things and lower it again if need be.
Before my final dolly edition, it was frustrating to wheel the dolly up to the tractor, perfectly centered, only to use the down riggers to raise it up to height and have the pivoting feet shift the backhoe over to one side or the other. Then I'd have to unhook the hydraulics and move the tractor to line it up again. That was the deciding factor to have the backhoe sit high enough on the stand to just roll it up and tilt it into place with the boom.
