Kubota F2400 D1105 3 cylinder electrical issues
DJthebigfella
Kubota F2400
Jan 3, 2025
15
Australia
Hi guys can anyone please provide me some advice. I thank you in advance.
I have just picked up a f2400 with a d1105 in it and i have no power going to my fuel solenoid or my gauges. The oil and Battery lights light up but not the fuel or temp gauges i have checked all the wires and all seems good i think the problem is the control module the part number that is listed for this machine is 76611-55710 but i can not find any photos to ensure the plug is right on the controller i will order. My plug is round i have attached photos of what my unit looks like.
The solenoid works when i put power to it however when it is all wired in i do not get power to it at all. Does the control module power the fuel solenoid? Is there a way to test the control module at all? or am i missing something?
I have been told parts for these machines will be hard to find in Australia as they were all imported and i am finding that this is the case. Is there a way i can by pass the harness and power the solenoid directly on like a toggle switch or similar. Thanks for your time
and happy new year.
3,500
2,094
I can't be of much help. There's an Op Man at Www.kubotabooks.com in the mowers directory that contains a wiring diagram in the back. Some Kubotas have a solenoid that is energized through a timer to shut down the engine, but I don't know if that function is performed by your operator presence module, or if your solenoid is energized to run.
I interpret the diagram as two molex type connectors, an eight pin and a two pin. Messicks shows a serial number break on the module so the part may have changed during production.
9,734
The OPS manual on Kubotabooks.com has the wiring schematic in it.
DJthebigfella
Kubota F2400
Jan 3, 2025
15
Australia
thank you
2,532
You may want to contact @Hugo Habicht about the combination box.
See post #26 in this thread where he rebuilds his combination box on a G1900
