Zd28 electrical/starting issue
yeltsin71
ZD28, B2850
Oct 6, 2024
New Zealand
Hi all
my ZD28 has ongoing issue with starting. Has new battery cables and new fully charged battery reading 12.87v
when cold it starts right up but when engine is warm it cranks too slowly to fire. Thought this was a CCA issue tries a bigger battery but same issue. When engaging starter I am only getting 11v at the spade connector on the starter solenoid (b/w wire). Battery charge is still at 12.8v
so I suspect a low voltage issue which is enough to crank engine when cold but not enough when hot. any ideas on where to look?
Fedup
347
141
Winchester
Hi all
You have 11 volts at the spade on the starter. Is this both hot (when not cranking fast enough) and cold (when it does start)? Have you tried applying battery voltage directly to the spade when it's hot and see what happens?
yeltsin71
ZD28, B2850
Oct 6, 2024
New Zealand
Still struggling with this and have decided it is the starter itself. Have ordered a replacement and will update with how I get on
davemskinner
Sold ZD28F, Bought04 Grnd L4330 /frnt mnt snwblwer L2185, hted/AC cab, 2nd ZD28F
Mar 12, 2011
98
Pulaski, NY
I've posted this in several other requests for help.
I have had 2 ZD28s. Both had this problem.
My fix was to put a 12v relay in the circuit such that the coil is fired by the key switch circuit (black wire with a white stripe) and the solenoid is driven by the N/O contacts feeding battery voltage (connected at the starter battery post) to the spade on the solenoid.
5,509
2,220
do a voltage drop test on the starter circuit. You'll find the problem. If you don't know how to do a voltage drop test, youtube search it-it's easy, and saves a TON of time.
it's probably a corroded wire or a corroded connection. Possibly a failing relay but you gotta actually FIND the problem before you can fix it.
Or fire off the parts cannon until it's fixed.
