Tractor stops when throttle is applied.
matt27919
L3902, LA526, RCR1860
Nov 5, 2023
Perquimans County
I have an l3902 bought new 2022. 97 hours on it. When I hit the hst pedal, the tractor dies. It throttle up all the way and idled at the 540 rpm mark for 15 minutes. I bypassed the seat safety switch with a 12 guage wire. I tightened the pedal safety switch nut. I have no idea what else it could be other than a wiring issue which kubota will not cover because it is 2 year amd 6 months old.
MOOTS
MX6000
Jun 27, 2019
2,189
2,718
Canton, Georgia
How did you bypass the seat switch? Picture? Has it worked before the problems you’re having today?
Moose7060
Oct 14, 2023
827
2,243
bc
Try taking the bypass out and put it back to normal. See if your stalling problem goes away.
MOOTS
MX6000
Jun 27, 2019
2,189
2,718
Canton, Georgia
I didnt need a bypass until today. And it worked when I parked it a few days ago.
That wire looks awful big to make a good connection. Male spade connectors fit better. If you have a multimeter, you can test the switch easily.
Went on a service call to a farm I service some of their equipment. Same issues, frozen switch. Pulled it out and got moving, reinstalled and it worked as should.
matt27919
Nov 5, 2023
Perquimans County
Thank you. I will try to get a spade connection and see what happens.
MOOTS
MX6000
Jun 27, 2019
2,189
2,718
Canton, Georgia
It tries to move. I can drive very, very slow. Like it's in a sort of limp mode.
I can do the same with my MX if I am standing and looking at my forks. Have to creep, like hardly move. My seat switch is not bypassed.
I’d bet your seat was just frozen enough to not press the switch.
6,013
be nice to have the WSM or al the very least the wiring diagram, otherwise it's a process of elimination. Hmm nc, so not icy and cold like here.....
sounds like it 'could' be the seat switch OR the wiring around it. look for cuts/slices/ open wires....
maybe post 2 pictures of what you have ? 'fresh pair of eyes' ?!
10,007
The safety switch above the pedal or something separate? Got to find a part number i can order.
Before you just throw parts at it use the WSM (aka service manual) to verify that is really the issue.
10,007
This is the part you will test then replace if needed.
6,013
Have a GOOD look at the wiring to it, whatever is nearby. it 'could' be that a wire has been 'sliced' or 'cut',so either open or shorted to ground. wiring diagram is a must to properly troubleshoot.
jschontag
L3902
Dec 26, 2025
Connecticut
I am currently having the same issue where the tractor starts and runs no problem, but will only creep with the lightest throttle, anything over 5% and it will stall. Mine is also an L3902, i attempted to close the seat switch circuit manually and i’m still having the same issue. I’ve done a lot of searching amongst the web and came across this post which seemed to maybe point me toward an HST sensor… curious if you ever solved the problem. My next step was going to check for continuity from the seat sensor wires to the terminals on the Main Ecu, assuming maybe the wires broke somewhere or a mouse chewed them possibly.
Any help is very much appreciated.
