B2650 hydro pedal creeps out of neutral
Newlyme
M4900 w/loader, finish mower, tiller, auger, rake. BX24 w/loader, backhoe
May 27, 2015
628
74
Nelson Ohio USA
There's a big difference between failing to return to neutral, and creeping into gear from neutral without being touched.
Agreed.
Are you sure it's creeping into gear, and not just failing to return?
It sounds like it is creeping from a stop while it is already in gear. And it sounds like it will creep in forward or reverse. If he put the gearbox in neutral, (if able to), there would be no creeping.
But.....He should not have to put the gearbox in neutral. If should not creep while the hydraulics are in neutral.
When I was having issues with my BX24 not coming to a complete stop when I took my foot off of the pedal, (returning to hydraulic neutral), I spoke with a Tech at the Dealer. He suggested cleaning/lubing the linkage, adjusting the return spring, or that there could be a issue with the internal hydraulics, and he said that I should hope it was not the last one, $$$.
The linkage was completely free and moved easily, I lubed it anyway. No difference in performance.
The return spring was all the way adjusted to the loosest setting, (the way it came new). Tight fit to get my hands in there. I took it to the mid point of the adjustment range. It made it better. When I remove my foot fast from the pedal it will now stop. When I feather the pedal to a stop it works 50/50.
I doubt that it is and hope that it is not a hydraulics issue.
PaulL
B2601, MX5200.
Jul 17, 2017
2,749
1,750
NZ
Yeah, the terminology is a bit confusing here. When I say neutral I mean HST neutral - i.e. stopped, I'm not suggesting he should have to put the range selector into neutral.
In his original post it sounded like he'd kicked the pedal to get it to return to centre, the tractor was stopped, and then the tractor on it's own crept back into forward motion. That sounds quite unusual to me, but not impossible, but like I say, a totally different problem than just failing to return to the centre cleanly. It would suggest the pedal pivot was off centre somehow.
But it is easy to misunderstand internet descriptions, so it's also possible he pushed on the brakes till the tractor stopped, kicked the HST to what he thought was stopped, jumped off, but it was never centred so it crept again. And that'd be a much more common problem that has known causes and fixes.
PHPaul
Apr 2, 2015
1,234
1,484
Downeast Maine
www.eastovershoe.com
This. Sorry if I wasn't clear.
What REALLY confuses me is that it will also creep into reverse on occasion.
I "feather" the pedal to take the load off the range shifter and get it into neutral. When I'm ready to put it back into gear, I have to diddle the pedal back and forth a little to get it back into gear without grinding.
This is what makes me think it's the neutral detent, or possibly the spring.
PHPaul
Apr 2, 2015
1,234
1,484
Downeast Maine
After (finally) finding a clear picture of the linkage and crawling under the tractor and watching while my BiL operated the pedal, I think I see the problem.
The spring on the linkage that applies pressure to the neutral bearing to hold it in it's detent appears to have very little (if any...) tension on it.
The lower mount on the spring is on the plate that holds the neutral safety switch. The bracket for the spring and safety switch appears to be mounted with a single bolt. I think I can loosen that bolt, rotate the bracket to put some tension on the spring and tighten it back down.
I'm going to give that a shot, I'll post back with the results.
7,454
PHPaul, it has to be more complicated than that! Someone had you thinking you'd have to remove the cab, and you just adjust the angle of the bracket from underneath?:D:D
PHPaul
Apr 2, 2015
1,234
1,484
Downeast Maine
Fixed!
I was close...the problem was the neutral switch was adjusted WAAAAYYY too far in and was keeping the linkage from returning to neutral.
Good news is, everything is reasonably accessible from the top after removing the access hatch on the floor of the cab. Didn't realize it was removable until I noticed the bolts sticking out from underneath while I was trying to get a wrench on the bracket bolt (impossible BTW with what tools I had available).
Yanked the mat and insulating foam out, pulled four bolts and the hatch and "Well, I'll be damned, look at that!"
You can see the bearing is not centered in the detent on the linkage. Bit of a booger to get at and I had to diddle the adjustment a couple of times to get it A) far enough back for the linkage to find neutral and B) far enough forward to let the tractor start.
Hopefully, it'll stay fixed now.
Thanks for all the ideas!
Newlyme
May 27, 2015
628
74
Nelson Ohio USA
Awesome. Glad to hear you got it.
Thanks for the pics!
rkidd
Dec 7, 2015
742
67
Jefferson Ohio
Been following this post. Glad to see you got it figured out Paul and can go back to really enjoying your tractor! I have over 1000 hrs on my B2650 now and have had to lube the linkage once in all of that time and it has been great.
Colin
B6200D, B1630, and B2650, LA534
May 14, 2011
Sebastopol, CA
So I just had exactly the same issue on a B2650 I just acquired a few weeks ago (yay!). The previous owner reported that it had just been serviced for a 'sticky pedal' but they (Sacramento For Tractors) had 'lubed it all up and it was now fine'.
Well, that lasted for about 15 hours of use before it started creeping both forwards and backwards, then it gradually wouldn't start. At first it was just one turn of the key with no cranking, but by the end of the day it simply refused to crank. It seemed to be related to the pedal as sometimes rocking it would let it crank.
In this case I was able to figure out that the Neutral Safety Switch was the culprit. By manipulating the rocker pedal I could see that the switch was not always getting fully depressed when in neutral.
So I wedged the pedal fully forward which leaves an air gap between the linkage and the switch, then tried manually pressing the switch piston. It was immediately obvious that the piston was binding up and was effectively resisting being depressed and thus providing a back force when near the neutral detente. This caused both issues, the creeping and the no cranking.
I pulled back the switch boot and shot into it with some PB (Penetrating Blaster) and manually pressed the switches piston until it moved relatively smoothly. And since then, no more creeping and it cranks every time. I suspect this is a temporary fix, with the fix being either a new switch or at least injecting some grease into the boot.
What i"m puzzled by is why isn't that boot filled with grease from the factory? If they had done that this would have never happened.
PHPaul
Apr 2, 2015
1,234
1,484
Downeast Maine
Update: It happened again. Lubed the linkage again and found the switch had died...again. Looking at $50 for the switch and a 120 mile round trip to go get it.
Need to add "Lube the linkage" to my maintenance routine.
Won't go into what I did about the switch, ifyouknowwhatImean...
GeorgeD
Kubota B2650HDB, LA424 FEL, Tipping Trailer, 3PL Pallet Forks, Fleming Tx Box
Jan 10, 2025
Scotland, UK
About a year ago I tore into why my HSD creeped when the peddle was released. Found out it was a bearing that rode the shifting cam. The little bearing was about the diameter of a quarter and three quarters thick. The Kubota costs for the bearing was $19.
I fixed myself... I put a post on this site complete with pics if you are interested.On my B2410 the fix was simple... but getting to it was a bitch...
I just saw PH Paul's WSM picture ... look at (2) that is the bearing I was talking about... my throttle is perfect now... good luck!
Hi Butch,
George here .. brand new member from Scotland, UK.
I've just traded my tiny Iseki and Kawa Mule in for a 2013 B2650BDH - European model. Unfortuately it was not a totally shrewd buy and I now see she's been sitting outside for years and soe parts have suffered. However, I'm still impressed by the power and also by power steering - what a luxury!!
I've just replaced a leaking hydraulic pipe which feeds the Bi-Speed turn unit from the PTO valve. It had been chafed/rusted by the return spring for the HST neutral finder. On a positive (and, of course also negative) note most of the issues I was having and the still existing ones are already on this forum.
A bit of an unfair question for you please ... did you have to use a puller to get that little bearing off?
Mine is a ROPS and not bad to work on. I had to dismantle most of the neutral mechanism etc to be able to wrangle the pipe in there so I noticed the poor state of the little roller bearing and the bushing. I tried to get it off to clean it up but .. no go. Given the rust and difficulties I've had elsewhere it's probably just rusted on but I thought I'd test your memory anyway!
Needless to say creep has started and changing LMH gear is different since I disturbed it. Having joined this excellent forum at least I know it's not just me or even the 2650.
Cheers, George
GeorgeD
Jan 10, 2025
Scotland, UK
Hi PHPaul,
Thanks for all your posts on this topic.
I noticed that bracket while I was replacing a hydraulic pipe. I had to slacken it and dismantle other bits of the neutral mechanism to get the pipe wrangled in.
Do you think that bracket is meant to be the adjustment for the spring tension or you just managed to find some free play in it? The WSM and Parts Manual don't provide any clues as far as I can see.
Cheers, George
PHPaul
Apr 2, 2015
1,234
1,484
Downeast Maine
Hi, George.
It's been a long time since I fooled with it so I'm going from memory, but I don't think it's intended to be adjustable.
Two notes:
1. After having had to replace the $45 safety switch several times due to it shorting out and blowing fuses, (safety nazis look away...) I removed the cussed thing and made a pigtail to jumper it closed.
2. I vaguely recall installing a stronger spring but I'm not sure about that. If I think of it, I'll crawl under the tractor and double check.
In any event, I haven't had a problem with the treadle since then.
GeorgeD
Jan 10, 2025
Scotland, UK
Hi, George.
Two notes:
Thanks very much. 'Appreciated.
ALL of my safety gizmos have been bypassed a long time ago it would seem. My switch is doing nothing (but maybe providing a little unwanted resistance to the pedal). I think I'll 'fix' it now.
Yeah. The spring almost certainly needs looked at. Given that the same rusty spring chafed and rusted through my bi-speed hydraulic feed pipe it can't be in great shape.
Wow! What a forum.
Many thanks, George
Butch
Kubota 2410, RC60-24B, FL1000- kubota hydrolic front snow blade- plug aerator
Sep 10, 2009
694
202
Rising Sun, MD
George.... I remember the "little" ball earing that rides on the cam plate that is actuated by the movement of the fwd/rev pedal. It was ca challenge to get to with out having to split the tractor... but I finally got it.
GeorgeD
Jan 10, 2025
Scotland, UK
Thanks Butch.
Access is easy on the 2650 ROPS. Didn't need to take wheel or mudguard off - just the transmission tunnel plastic cover and the lever cover and the step. I removed the bearing circlip and tried to lever it off but it wouldn't budge.
No surprise. I just bought a 740lbft air wrench because of the tractor and it's been needed 3 times so far .. and I haven't broken anything ... yet!
I'll try a puller.
Cheers, George
2,818
George - I hope you are using a GOOD rust penetrating oil. Here in the USA we have several different kinds like PB Blaster, Kroil, Mouse Milk, Deep Creep…
They are very good at dissolving the rust and getting into the small passages and making removal easier.
GeorgeD
Jan 10, 2025
Scotland, UK
Thanks Russell.
Probably not.
I've only been using Plus Gas thus far and it's not great. However, I have noted PB Blaster being mentioned on this thread and checked it out on Amazon UK. Expensive .. but I'm sure it's worth it. I'll check out the others you mention too.
Many thanks again.
Rgds, George
PS:
I don't suppose you have any recommendations for diesel/injector cleaners? Mine does not have a DPF.
It starts OK (albeit with quite a bit of smoke) and runs well but, considering its sorry state, I'm working my way through service and recovery procedures.
Butch
Sep 10, 2009
694
202
Rising Sun, MD
Thanks Butch.
I'll try a puller.
Cheers, George
My bearing was shot! All but 2 of the balls were there and the outer race just fell off in my hand. It took a little bit of time but it worked like a charm! I took a little stone grinder and a Dremel tool to gently grind the inner race. When I got close to breaking through .... it just popped apart and I slid it off with my fingers. Eazy Peezy!
2,818
Thanks Russell.
Probably not.
Many thanks again.
Rgds, George
PS:
Looking quickly at Plus Gas it seems to be similar to Three-in-One oil which is common in the US. It is a light weight oil.
It does work but these newer formulations are much better and work faster. They are not “miraculous“ but much better. They are chemicals that seem to be able to break the rust down and carry it away. The PB Blaster is labeled as a “rust catalyst” but no idea what that means really.
The Kroil is expensive here and has a strong odor that is offensive to most folks.
I don’t know of any good injector cleaner but some people have recommended Power Service.
Good luck with the tractor
