It has been a long while since last post. Previously I posted repair questions regarding my B1750 hyd. pump replacement. Dan (old hokey) was an immense help!!! He set me straight on everything from where to buy pump to setup and relief valve settings.
I sold the tractor 2 years ago to a friend with no problems to speak of. Recently repacked lift / curl cylinders and did a pressure test at work port. It was running low - 1400@2000 rpm. Increased loader relief valve to 1600 as high as it would go.
Checked pressure at block - also 1600psi.
Pulled relief valve from block and would like guidance shimming/adjusting pres. relief before I attempt to do the job. (I returned the loader valve relief to original pressure until main pressure is at normal psi.
New pump was previously installed, screen is clean, fluid flushed.
Pictures are attached.
Hopefully Dan or Wolf man will respond but any first hand experience will be appreciated. T. Y.
