Tire Chains vs Concrete
Stmar
B2650HSDC
May 23, 2017
949
58
Buffalo, Wyoming
Have a set of chains, combination of cleats, some fairly aggressive, front and back. Problem is we got a nice concrete pad poured this year in front of the garage. I am thinking that the chains would do a number on the concrete unless there is a cover of snow or ice. Any ideas/experiences with chains and concrete? Definitely do not want to damage the pad so may have to depend on 4wd without the extra traction of chains.
hedgerow
457
442
Malcolm NE
I have pushed al lot of snow on concrete with chain on but I am not running anything with chains on it on my concrete. A green slab like that and chains are not going to play nice. Back before FWA tractors I always had a set of chains on a tractor to feed cows and push snow on the rock drive way and the lot. That tractor stayed in a shed plugged in with no concrete. If that tractor needed to go into my shop the chains came off. Some folks don't mind chains on there concrete I am not one of them.
10,795
Yea chains are hard on Concrete, If i need to pull them into the garage, I use stall mats to keep the chains from digging in.
Stmar
B2650HSDC
May 23, 2017
949
58
Buffalo, Wyoming
Thanks for reinforcing my thoughts, really don't want to mess up the new pad $$$$$, concrete is not cheap. Took chains off, expecting snow this weekend and if I don't get carried away 4wd will do just fine. Chains were more for security going downhill when icy but I can usually mitigate that with enough patience and care.
OntheRidge
Nov 1, 2020
490
582
I put a set of these on my L47 at the end of last winter. Off for the summer, so I cannot say how well they work. I will find out Monday, if the weather reports are correct. An option if you find you still need chains. Good Luck!
pigdoc
G1800S L2500
Aug 19, 2022
398
344
SE Pennsylvania
My immediate thought is to visit your local dairy farm and ask them if they have any "cow mats" that they are discarding. Or, get some beat up rubber belting that has been replaced. Maybe from a quarry? Tractor Supply sells new cow mats, but you don't need that, you want the sh_t that's on the trash heap.
-Paul
GrumpyFarmer
5,070
Good day.
I have same concern and interest.
I’ve actually thought about studding my tires because I think it would be less aggressive but add some needed additional traction. Been planning to do it for going on 3 years…still not ordered.
That been said there are some pat threads on studs maybe worth a search if interested in some middle ground.
Either way chains or studs, I think if get too happy with throttle it’s going to leave a mark.
6,257
The 20x24 pad(smoooooth finish ) in front of garage is 30+ years old, NO damage due to 1,000 # rider with loosey chains. Mind you it's taken a beating from the 7,000# forklift for 15 years. Mix was 3500#, think I should have gone 5,000. Also guys didn't put the base down I wanted.... oh well...next time.
5,167
Although not an "apples to apples" comparison, I keep some aggressive chains on my Rhino 660 year round and I park it on my concrete floor in the "barn".
I have never noticed any damage yet. but it sounds like hell.
But I am also just pulling "into and out of " the barn, not "working" on it. I also realize that the Rhino is way lighter than you tractor.......
Just an observation.... (y)
b454rat
B7100HST B6100
Dec 10, 2022
67
Windsor NY
just "driving" on concrete with chains will be fine. It's when you spin the tires the damage can happen. My parents house had a concrete garage and blacktop driveway, my old man got mad when spun the tires on either, to the point we took em off.
Shawn T. W
Dec 9, 2024
741
1,358
SW Missouri Ozarks
My brother in Vermont mentioned he ran chains at his new house, I questioned him as I haven't been there, but thought he had a paved asphalt driveway ... Here is his response to my text ...
On his B series ... He is very happy with them.
Stmar
B2650HSDC
May 23, 2017
949
58
Buffalo, Wyoming
My chains started off same as these rubber chains, they started to deteriorate after some years so I replaced some of the rubber tread with chain. I may take the chains off and replace with rubber.
