L2850 sight glass replacement
Selkirk_D
Kubota L2850DT-GST
Dec 5, 2024
180
165
Northern Idaho
Happy new year all! So, much to my dismay, I thought my new to me L2850 had moisture in the hydraulic system because the sight glass was “milky” looking. Fortunately, when I drained the Hyd fluid out, it was clean and clear. Upon closer inspection, it appears that the PO completely gooped up the sight glass with a whitish sealant I assume to stop it from leaking. The “glass” has a star fracture in the middle. Problem is, I can’t see the oil level due to the goop. I need a replacement. I can’t find a replacement glass in the Kubota parts diagrams. Does anyone know a part number or a source for a replacement glass?
Is it pressed in with an o-ring or threaded? I’ve seen a company called JW Winco that has various sight glasses. I’d appreciate any advice on best option, thanks.
Selkirk_D
Kubota L2850DT-GST
Dec 5, 2024
180
165
Northern Idaho
Awesome, many thanks, I’ll hit up my local dealer tomorrow just in case they have it. Again, much appreciated.
Flintknapper
L2350DT
May 3, 2022
2,024
2,577
Deep East Texas
It should have a rubber/silicon seal around it, but I used a light coat of oil resistant automotive sealer around the seal before installing mine, just the same. (for L2350 shown)
10,941
Selkirk_D
Kubota L2850DT-GST
Dec 5, 2024
180
165
Northern Idaho
Ever use 3-Bond 1104? Great stuff for gluing motorcycle cases together. Tough, elastic, impervious to oil and gasoline. Ultra rtv is a great tip too.
I appreciate the advice and the info. Thanks guys!
10,941
3 bond works excellent on cases, metal to metal.
Doesn't work as well as Ultra RTV on rubber to metal.
Selkirk_D
Kubota L2850DT-GST
Dec 5, 2024
180
165
Northern Idaho
So although Coleman’s listed it as in stock, it’s not. 3-4 week lead time due to !&$@&#%^ Kubota blackout. Hope local dealer has it!
Messick’s says they have 2, we’ll see
10,941
If the local dealer doesn't have it ( which knowing your dealer I bet they don't), Call messick directly as they will ship USPS for less, but it is slower shipment.
I'll look in my stash as I might have one laying around, I'll let you know if I find one.
Selkirk_D
Kubota L2850DT-GST
Dec 5, 2024
180
165
Northern Idaho
It was a long shot, but they don’t have it. I ordered one from messicks, says it will ship today. We’ll see. If you have one laying around, I’ll definitely buy it. Thanks for the offer!!
Messicks says it will be here Wednesday !
Selkirk_D
Kubota L2850DT-GST
Dec 5, 2024
180
165
Northern Idaho
Messick’s order arrived a day early. Pressed new glass in with thin coat of black ultra RTV. A bit of a challenge when it’s this cold, but by using a small pry bar backed with a rag, I was able to carefully press it in with no damage. All good, thanks for the help guys!
