LA1065 Frontend loader
Adared
Mx5200, LA1065
Jan 1, 2025
Mississippi
Hi, newly tractor owner, i purchased a used Kubota MX5200 with LA1065 loader, it has worked great since i've had it, Recently the loader has been slow to go up. I am totally green to tractors so any suggestion will be appreciated. Also i've notice the HTS doesn"t seems to Stop when you let off the petal. Not sure if this could be connected to other problem.'
MOOTS
MX6000
Jun 27, 2019
1,963
2,273
Canton, Georgia
There is a damper for the pedal. Could also be something jammed in the linkage. As for the slow loader, have you recently disconnected the quick couplers? They can seat enough to not leak but also not let full flow through them. Try disconnecting each and reconnecting.
Adared
Mx5200, LA1065
Jan 1, 2025
Mississippi
Thanks MOOTS, i haven't disconnected the quick couplers, but i can check them out, i did notice that my tractor was low on hydraulic fluid, could that be the problem?
6,862
Yes low hydraulic fluid could cause the loader to act erratically.
But the fluid would have to be VERY LOW or the tractor operated on a very steep grade.
Adared
Mx5200, LA1065
Jan 1, 2025
Mississippi
Thanks Wolfman, after adding utd it seems to be working normal again. i talked to the dealer about the HST and he agreed it most likely the Damper, Anyone know the part no for it. ive looked and looked with no luck and how hard is it to replace?
6,862
All super easy fixes:
Check this spring too:
Spring: Green
Neutral holder bearings: Blue
Damper: Yellow
