Zero Turn Blade Changing Ideas
LarryBud
L3130
Dec 5, 2020
255
134
Cleveland, MO
Hey Folks,
I have a 52" Gravely. Last time I changed the mower blades ( I have two sets ) with sharpened blades I removed the deck, flipped the deck up on the side and proceeded as described in the manual. Removing and reinstalling the deck, belts, springs is no small job on this model. It seems like way too much work for sharp cutting blades.
I was thinking of just using my loader to lift up the front, blocking it somehow and changing them right there. Any better ideas? Other thoughts.
Flintknapper
L2350DT
May 3, 2022
2,024
2,579
Deep East Texas
Yes, come up with something.
Just be sure to block it well or otherwise secure the deck.
I use an engine hoist to lift the front of my Scag and just change the blades that way.
Just hook onto an eye-bolt I installed and lift it.
dragfan66
B7500 Z231KW G1800 L3350DT
Apr 12, 2020
65
74
Alabama
I have used a loader several times at the farm to do exactly that. I raise it up until the rear bumper is about on the ground. I rotate the spindles to get a feel for any problems with the bearings first.
Then swap the blades quickly without exposing myself to possible chain or loader failure.
At home, I use a MoJack.
jyoutz
Jan 14, 2019
3,625
2,718
Edgewood, New Mexico
I have a chain hoist attached to the trusses in my barn. I just lift the mower that way.
Marky
L2502DT, Ford3000
Oct 24, 2024
40
99
Georgia
I just roll a floorjack under the front and lift it enough to get an impact wrench onto the bolts. Couple of minutes and i’m done…
Old Machinist
May 27, 2024
719
840
NE FL
I use car ramps and a creeper to change the blades on my MMM.
I also use a short piece of chain with hooks on both ends to hold the blades secure while I torque the bolts.
11,124
I just roll mine off the side of the mountain.... Oh wait... maybe that was an accident and not maintenance. :unsure:
Flintknapper
L2350DT
May 3, 2022
2,024
2,579
Deep East Texas
I just drive one caster up on a car ramp.
That's what I do to clean the underside of the deck. IF you wash it with a hose immediately after mowing, it cleans very easily and quickly.
If you wait until it dries and builds up, then you have scrape it.
Much easier to 'maintain' things then have to fix something later.
Cleaning the deck takes no more than 5 minutes for me and I am 'ready' to mow next time.
Outnumbered
Kubota L3901, FEL, BB1260, RCF2060, FDR2572, Forks, 55" Grapple, 5' Tiller .....
Oct 26, 2019
268
488
Moseley, VA
Chain, battery impact wrench and two jack stands and I am done in a few minutes.
Flintknapper
L2350DT
May 3, 2022
2,024
2,579
Deep East Texas
Great picture. That is about the same angle I lift my Scag using an engine hoist. Easy access to the blades. I don't give 'Blade Changes' any thought....since it can be accomplished in less than 10 minutes.
I always have a couple of sets of spare blades sharpened and ready to install. I will put about 200 hours per year on my Zero Turn maintaining our lawn and property. So I need a quick and safe way to change blades.
LarryBud
L3130
Dec 5, 2020
255
134
Cleveland, MO
Lot's of good ideas shared. Thank you to all who replied. I think my first mistake was reading the Owners Manual.
InTheWoods
B7510/FEL, B7100D, ZD18, ASK-R130
Nov 17, 2023
279
231
Indiana
Good for your midget slaves to work under
Ha.
I do have to get down on the driveway, but there's plenty room to get the blades on and off...
And, I'm confident it won't crash down on me.
