Lets see your weld on bucket hooks
Tarmy
L2800, BH76A, FEL,box scraper
Nov 17, 2009
483
410
Lake Almanor, Ca
Bolt on dont count 🤣
Hey now…I did weld them to the plate!
I had welded them on the original bucket which was before I installed the quick attach plate. I found that in certain odd applications I may want to switch around the D rings so I did the bolt on plates for this one.
g_man
Feb 3, 2023
170
758
NE Vermont
I put some shackle lugs on my FrostBite Grapple.
I can hook stuff in a variety of ways
I found most of the time I just wanted a grab hook and didn't like the complication of the shackle just for a grab connection so I added a grab hook too
I bought a used M5640 that had a middle bucket hook. Added A set of hooks and a lug in line with the Loader Arms. First hook I put on backwards - DUH - Decided to leave it and put one on both sides with a correct facing one. I actually use the backwards hooks for hanging heavy stuff close the the lift pins.
gg
Old Machinist
May 27, 2024
132
127
NE FL
This is how I modified my light duty JD bucket. I cut one leg off of a 4x4x1/4 piece of angle with a plasma cutter leaving about 3/4" on the front side. I cut one leg off some forged HF hooks and welded those onto the top. I used the leg I cut off the angle to make pieces to reinforce the side like the HD bucket has.
John T
2017 BX23S
May 5, 2017
868
339
under a rock
I agree with attaching in line with lift arms, but have never saw the need for a center hook. I always attach my lifting chain to both hooks, then drape and connect the hook to the chain in the center of the bucket to center how the chain hangs. It’s stronger because the weight is distributed to both hooks, yet the lifting chain is centered.
I never put a center hook either.... but it might come in handy when using a long chain..... you can loop the extrachain in the middle instead of dragging it and running it over with the tires.... :LOL::ROFLMAO:
jyoutz
Jan 14, 2019
3,053
2,098
Edgewood, New Mexico
I always stick the extra chain inside the bucket.
JRHill
Orange: B7100 Std and Woodmizer; Green/yellow JD Buck, Gator and 410j.
Apr 26, 2016
137
90
Wahkiacus, Washington
Both the tractors have chain attachments but where I really like the welded hook is on the receiver hitch of the Gator.
