Water in diesel
Pjridge
L3302
Jan 23, 2024
Tn
I
Is this water contamination? This come out of my transfer tank. Luckily I haven’t transferred any in my tractor.
5,152
It might just be foam. Water falls to the bottom, so set the jar on the kitchen counter and leave it undisturbed for the evening. Then gently lift it and see if water is on the bottom. Your sample is quite small to be checked, but water is difficult to hide and you should see it.
Pjridge
L3302
Jan 23, 2024
Tn
If that bead is on the bottom, it's water. Looks like it.
Yes it is. That’s what I was thinking. The only reason I check it in the first place was the pump wasn’t threaded in completely onto the tank. Rain water I suspect. I have a 20 gal poly tank with pump like shown.
The pump doesn’t thread to the tank well and will loosen up. It’s a good setup other than that. Any input is appreciated.
8,851
Use tru-blu pipe thread sealant on the pump threads and it won't loosen up.
The Evil Twin
L2501, LA526,
Jul 19, 2022
3,120
3,381
The quantity in the tank is near impossible to determine from that sample, but I have had the same amount in my truck water separator without even knowing (till I drained it). You could buy an in line water separator for the pump and keep an eye on it. Now would be the time to add the appropriate amount of bio treatment to keep the growth at bay.
Pjridge
L3302
Jan 23, 2024
Tn
It is treated with bio. I’m going drain it, figure out how to fix my pump mount and add a separator. Thanks for the link.
woodman55
L6060HSTC, RTV 1100
May 15, 2022
1,050
868
canada
Put it in the freezer. In a few hours you will know if it is water/ice, or not.
