Up front disclaimer: I am not a gear head. My unofficial motto is "If it ain't broke, fix it until it is."
Need to replace the fan belt on a 1980 B7100, gear drive trans, 3 point, with Kubota end loader.
The hydraulic pump mounts on the front and is driven by a shaft on the drive pulley. On either end of the shaft is a double section of roller chain. I have no idea what these chain sections are for.
I have the B7100 owners manual and parts manual and the manual for the loader. There is zero info on a front mounted pump.
Question: Can I disconnect and drop the shaft between the pulley and pump by splitting the roller chains?
OR do I have to disconnect the lines from the pump and drop the pump?
I found an old thread by a guy with the same problem. One member recommended using a link type belt but no other "fix".
You help will be desperately appreciated.
Regards
Jim
Regards
Jim
