Up for sale is a Kubota L2850 tractor 4x4. 34hp diesel. It is a manual but I had it adjusted a while back so you don’t have to put in clutch to start. Starts right up. Clutch was recently replaced as well as both front axle hubs. Has M series bucket with tooth bar. Grader and 48” solid steel brush hog are included in sale as well. Only has one small issue key won’t turn off engine so have to use fuel cut off lever which works effectively to stop engine. Rear tires are filled and all tires have tubes. Has been regularly maintained since I bought it in 2014. This is a great running low hour tractor (1517 hours) pre emissions tractor. $12,500. Brush hog, grater, bucket, pto drive all included in sale.
