New here but had my B7100 for quite some time.
I'm trying to get access to the bottom of the engine via removing the oil pan. However there is a drive shaft overlaying it and I'm not sure where I should disconnect it and if I do whether a whole lot of oil or other fluid will come out.
Secondly there is a water pipe which i think sends coolant to the hydrostatic fluid pump. It overlays the oil pan bolts on one side so they can't be removed without disconnecting it. I've taken one end off the radiator. Looks impossible to remove the end under the steering wheel without taking off the drive shaft.
Seen a few comments in here about people doing this but no detailed description so any advice or handy hints would be appreciated.
