Hello,
I've read other posts on this topic. My tractor sits a lot and outside all the time after 2 days of 10F nights, day was 20F and I started tractor.
Moved about 100' putting loader into a snow bank to move it and all hydraulics went dead: steering, F/R shifter, 3 pt and loader.
My neighbor brought down his Landini and pushed me back to near barn.
Today its 44F: Tractor started and hydraulics are all working.
There could be a tinge of milky on rear dip stick but hard to tell being a short surface and light oil.
In the past 2 years I've blow 2 different hydraulic hoses and when I replaced them did a complete drain and changed both filters.
I'm going to do another complete drain including filters and new oil.
Question:
If I can get the small set screw type plug out of the steel line under the hydraulic pump and I use air to blow line back to transmission case will that work/ or do I need to disconnect both steel line flanges from under the pump.
Thank you for the help!
Question:
