x1140 black smoke and power loss at full throttle
Walpko
RTV x1140
Dec 18, 2024
PA
I have a 2017 RTV x1140. Ran great until lower rad hose came off and fried the engine. Had a new engine put in and hasn’t ran right sense. Idles fine but at full throttle on flat ground it smokes and going up hill it just about stalls if you don’t let of the pedal, and blows smoke like crazy. I thought the IP had a stuck plunger but it didn’t. I replaced anyways and still no luck.
Things done this far:
Checked air lines and filter
Replaced fuel filter
Replaced injection pump
I’m not sure where to go from here
woodman55
L6060HSTC, RTV 1100
May 15, 2022
1,050
870
canada
Plugged air filter ? Lack of air will make them run rich, and bog out.
11,099
Curious why you would replace the injection pump?
Black smoke mean over fueling not under, a injection pump can't over fuel.
Injectors on the other had can over fuel.
Did they replace the entire engine or just a short block?
Sounds like either the spill timing is off or the injectors are bad.
Walpko
RTV x1140
Dec 18, 2024
PA
I had “mechanic” friends helping me and the common suggestion there was IP as these IPs have been known to freeze up. Which it wasn’t and I got desperate and just threw a new part at it. As for spill timing, what is that? And how does one check it?
11,099
When you replaced the Injection pump was there shims under the pump?
Did all those shims get reused?
Did you use any RTV under the injection pump to seal it?
Those shims set the timing, and the way to verify if the timing is right is to do a spill timing test.
It is covered in the WSM (aka service manual).
Walpko
RTV x1140
Dec 18, 2024
PA
When I removed the IP there was only 1 shim under it. I will do that test tonight and let you know
Walpko
RTV x1140
Dec 18, 2024
PA
Sorry for the delayed response life got busy with the holiday. My manual does not show how to spill test so I youtubed it and I understand now. Only question is, is there any other way to check timing without pulling front cover? If not oh well, just thought I’d ask before I disassemble completely
eserv
BX24, A1000 Kubota Generator
May 27, 2009
2,190
171
Hardisty, Alberta
You don't need to remove the cover to do a spill test
eserv
May 27, 2009
2,190
171
Hardisty, Alberta
How can I see the flywheel? It’s attached to the tranny?
There should be a plug on the bell housing that you can remove to see the marks. I haven't seen a RTV1140 for 6 years or so and I never did a spill test in one but I have done it on many other models. There are no marks under the cover that will help you set the timing. ( Unless the engine hasn't been assembled correctly)
Walpko
RTV x1140
Dec 18, 2024
PA
After you said that I started looking and theres a rubber grommet like your saying. So there isn’t an electric fuel pump that I’ve seen or heard, how will I get fuel to flow?
I hope these aren’t dumb questions, this is most involved I’ve gotten into dealing with an engine like this
eserv
May 27, 2009
2,190
171
Hardisty, Alberta
It has a mechanical lift pump with a lever on it, just pump it up. There will be enough residual pressure to see the spill happen
