Chip DPF Delete Discussion
troverman
Jun 9, 2015
1,188
275
NH
I haven’t found anything not to like. In the winter I wish I had bought the cab model, but I know I would destroy it in the summer when cutting between the trees.
I wish I had both an open and cab tractor, and you are right, you can damage things on the cab. I broke one of the amber flashing lights that are near the roof on a tree branch already. That said, I'm mowing 30 acres of field in the summer and having A/C with a cabin filter and not breathing all the pollen made it worth the extra cost. Having heat in the winter is just icing on the cake.
jyoutz
Jan 14, 2019
3,032
2,083
Edgewood, New Mexico
I try to mow a few days after a rain. But I have resorted to a face mask before. AC would be nice, but it really doesn’t get too hot here. I mow 20 acres.
SDT
multiple and various
Apr 15, 2018
3,260
1,049
SE, IN
I would work there for a month and then move to Montana.
Not a resident of a blue state but planning to relocate to Montana in the near future to be near my only son.
Wonderful place, but with a low population, easily turned by immigration, legal or otherwise.
SDT
Apr 15, 2018
3,260
1,049
SE, IN
I’m wondering why you would want to avoid a regen? It doesn’t stop you from working and is over in 10-15 minutes.
Because (in my case at least) regens seem to always occur when I am finished and heading back to the barn. Maddening!
I have gotten into the habit of hitting the inhibit button a few minutes before finishing a task on tractors without a DPF scale, e.g., L6060. I pay attention to the DPF monitor on the L6060 and only hit the inhibit button if it is close to regen and I am nearing completion of a task.
Fortunately, I plan to downsize and relocate in the near future and will dispense with all such toys when I do.
SDT
Apr 15, 2018
3,260
1,049
SE, IN
Not running emissions equipment on modern diesel military equipment is a tacit admission of the unreliability (and added expense) that us mere consumers are required to bear, all to 'save the planet' of course. You could use the argument that the military doesn't use an SCR (DEF) system on their diesel equipment because of the possibility of not being able to get DEF in remote areas and having the vehicle shut down. However, argument doesn't hold true for other emissions systems such as a DPF or cooled EGR, which military vehicles also lack. Neither the EGR nor the DPF systems improve engine performance, they strictly are in place to control emissions but have the downside of creating serious reliability problems, which is of course why the military doesn't use them. I've heard sworn testimony from current top-level ranking military leaders that the biggest threat the US faces isn't foreign enemies, but rather is "climate change." The hypocrisy is rich, given if that really were the case, the military is not utilizing these longstanding diesel engine emissions controls devices. And you are 100% correct on aircraft emissions as well.
Bingo!
That said, greenies are pushing to force the US military to comply with commercial emissions regulations.
There seems to be no end to the insanity.
SDT
Apr 15, 2018
3,260
1,049
SE, IN
I have 60 hours on my new tractor and have yet to experience a regen. Dealer says it’s because I’m running the RPMs right. It’s not a frequent process.
Almost certainly, it has happened and you simply haven't noticed.
Botamon
Mar 26, 2018
286
517
Winnemucca, Nevada
This is me. Unless I happen to see the regen light on in the dash I don't know it is happening. I've seen posts where people claim that the tractor sounds different and smells different during regen but I've never noticed either with my Kubota. If it weren't for the light coming on I wouldn't know.
I've also seen claims that the regen process uses a lot of diesel. But I'm pretty sure my Kubota uses less diesel at PTO rpm than my old John Deere, yet it is a higher horsepower tractor.
5,246
1,927
M7060 with low/side mount exhaust certainly has a different tone during regen. I've found them to have a slight "backfire" sound. Also the air intake tends to emit a slightly different tone as the air valve (aka throttle) shuts a little bit as commanded by the ecu. But frankly, unless you listen very, very closely, you can't tell it's happening. If it weren't for the ignorant light in the dash, 99% of folks would never know.
5,246
1,927
by working for someone they are making money. If they are in the state of california, by working for em you're supporting them and then supporting the state.
I refuse to do all of the above. Just my preference. Money or not. I have been broke and homeless, I know what rock bottom is. And I'll be broke before I support something I don't agree with.
SDT
Apr 15, 2018
3,260
1,049
SE, IN
Similar with my M9960 with horizontal exhaust.
Always smell heat when my B3350 regens but rarely notice when the L6060 does unless watching the lamp. L6060 is clearly the most smeamless.
Never notice anything with my ultra reliable B1750HSD, and never an need to hit the inhibit button.
5,246
1,927
b1750 is permanently in "inhibit mode"
mzimbaro
Kubota B3350 with La534 Loader, B2782 Blower and RC72 mower.
Aug 2, 2021
15
Ontario Canada
I hate to rehash this thread but I need to get my two cents in especially since i just went through two regens just two hours apart wasting half a tank of fuel. These idots that are making the laws don't understand that by making all users comply the following carbon producing issues happen:
1) Users need twice as much fuel than non dpf systems
2) Oil produces need to produce twice as much oil for diesel users
3) More oil needs to be refined
4) Engine life and component life is greatly shortened needing far more replacement parts
5) More parts need to be made
6) More parts need to be shipped all over the continent
7) I need to drive 50 miles way more often to the dealer to get my parts.
In case you didn't know, all of this takes energy which is created and creates more pollution.
JonM
Kubota Grand L6060
Nov 29, 2024
wisconsin
the whole point of this emmission stuff is because if the gov doesnt have the votes to outright ban the ownership of internal combustion motors they will make it it as expensive and miserable as possible to get you to give them up.
mcmxi
6,471
NW Montana
We're all familiar with the expression "smoke and mirrors". Illusionists get the audience looking in one direction as a way to conceal what's actually happening in another direction.
Bmyers
May 27, 2019
3,306
3,888
Southern Illinois
Don't worry about these old standards, the new ones are just around the corner to replace these old outdated ones.
  • Sad
6,594
Do you know hydrogen engines require Zero emissions systems.
Just saying.;)
