RTV 400 Fuel System Conversion
T Skaggs
RTV400 ci
Nov 7, 2023
Muskogee
I have a RTV 400 with fuel injection, the ECM is bad and very expensive to replace, is it possible to remove the injection and install a carburetor?
6,279
sure you can (some conditions apply, E&OE ) ....
step 1. get make/model info of the current engine
step 2. see if maker has same engine, but carb version
step3 ..compare 'bits and pieces' to see what's needed
step 4. price out the 'bits and pieces'..is it cheaper than an ECM ?
BTW what's 'bad' with the ECM ?
3,826
2,383
It's been a while since my one encounter with a 400, and my recall is sketchy. But I remember considering replacing the EFI with a carburetor.
Does that ECM also control the spark? If so, you'll also have spark to consider.
The engine was designed by Subaru from their EX40, used in Club Cars and other applications, which used a carburetor and rated at 14 hp. They apparently added the EFI for Kubota. Robin got involved and Subaru exited the small engine business. You can still buy a Robin EX40. You may be able to adapt some EX40 parts to your engine, I don't know. You'd probably have to come up with a manifold, air cleaner and carburetor/transmission linkage, at least.
T Skaggs
RTV400 ci
Nov 7, 2023
Muskogee
the ECM will not put out enough voltage to fire the injector
6,279
hmm... is the injector resistance now too high ?? Any 'spec' on it like ' 2.05 to 2.45 ohms'
are all the wires and connections clean and tight ?
Injectors require a lot of power for a brief time so it is 'mission critical' electrons can easily flow.
The actual ECM may be fine, several other things can be suspect though.
is this the beastie ?
for sure you'd need to clean ALL of those connections and ensure a tight fit to cables.
T Skaggs
RTV400 ci
Nov 7, 2023
Muskogee
When I ran a voltage output test on 116-117 I was supposed to get 5 to 7 volts but I had zero volts on those pins.
6,279
without seeing the documentation, it sounds like the 'output transistor' or whatever active device they're using has 'opened' or PCB traced has opened or solder connection of connector to PCB has failed.
1st and 2nd failures should be 'rare', #3 is common as wave soldering big connectors AND SMT devices on same PCB is a bit of an artform. Too much heat/time...little pieces fall off, too little and connector joint is 'cold'( will fail in future....)
T Skaggs
RTV400 ci
Nov 7, 2023
Muskogee
Just an update, I have found a carburetor that was inexpensive and it bolted right on, the linkage even matched up. It will run briefly but the high pressure fuel pump will flood the carb. I am in the process now of installing a pressure regulator.
3,826
2,383
Can you do away with that pump and use a 12v pump from AutoZone or Advance? When you get this running, you need to start a thread with all the details.
T Skaggs
RTV400 ci
Nov 7, 2023
Muskogee
Another update, I did as suggested, I purchased a 12V pump with a PSI rating of 4-7 and it works perfect I took the high pressure pump out of the tank and with a little modification I attached a pickup hose and filter. It runs well in the shop, I have yet to get it outside to see how it preforms but it raps up and sounds good in the shop.
hedgerow
469
452
Malcolm NE
I had a Kohler we switched over to a carb and even using a 4-7 PSI pump I still had to install a regulator after the fuel pump and turn it down to 2 PSI or on a warm day it would flood the engine sometimes. After installing the regulator I never had another issue and its been running for years that way. Just food for thought.
T Skaggs
RTV400 ci
Nov 7, 2023
Muskogee
Thanks for the info, I will keep that in mind.
6,279
hmm, any chance you can tie into 'valve cover vacuum' ? If so, use one of the 'vacuum' operated gas pumps as seen on lots of riders. B&S, Kohler, engines. Might be an option ???
here's a sample of what I mean and used....
I'm sure Amazon sell them....
Jt525
Kubota
Jun 10, 2025
TX
Thank you for this thread. My father is having the same issue with his 400CI. How's your rig been holding up with the carb conversion?
Pat M
2012 rtv 400ci
Dec 16, 2025
Alabama
Anyone have info on the carburetor used , my ecu recently went bad and is blowing fuse, dealer said replace with the $2600 new unit
T Skaggs
RTV400 ci
Nov 7, 2023
Muskogee
Search Amazon or Ebay for a Subaru EX40 carb. I had to drill the jet out one size to get the proper fuel mixture, if not the unit will not run well.
T Skaggs
RTV400 ci
Nov 7, 2023
Muskogee
It runs great! No issues, I've had it in the woods multiple times now and it preforms great!
