Where (online) do you buy your after market parts?
Dan Powell
Kubota Cab 4WD 60/40, Kubota Cab 4WD M8500, Fiat 65/56 DT
Oct 24, 2017
Harrison AR
Looking for a windshield washer tank for my M8200 cab tractor. Spoke with my local dealer. They want almost $250.00 for the tank and pump. Where do you buy your online parts?
Also, where do you find the part number?
2,968
Their prices will be very much in line with your dealer ......... and then there is shipping!
You may need to be able to use something else to achieve that same thing for you pump and tank
Dustball
2016 B2650HSDC
Sep 15, 2023
484
351
Hudson, WI
Taking a guess on the sub model you have. I did a spot check on the other sub models, looks like the washer tank assembly is the same. Do you actually need the whole assembly or just a part of it?
9,999
You will not find aftermarket parts that will cross to the part number, or be an OEM fit.
You will have to find a generic tank and pump and retro fit it, not really the smartest option.
JimmyJazz
1,272
805
Pittsburgh, Pa
Bite the bullet and call Messicks. Stuff breaks thats to be expected. What did that tractor cost you ?
6,011
I wonder what's wrong with the tank ? If split(due to ice) , easy fix as it's plastic. If pump, replace or repair ?
Have to admit $250 is a huge price to pay for $5 on plastic and a $10 pump though...
