GF1800 Wiring question
TimAT
GF1800 4x4 60" Mower
Oct 5, 2023
36
Kansas City. MO
The previous owner removed the dynamo and installed an internally regulated altenator. No idea what the output amps are. I'm guessing more than the OEM dynamo. Regardless, it is charging the battery per my handheld voltmeter.
The charge light on the dash does not work. Does anyone have a wiring diagram that shows how to hook it up so the light function is restored? The OEM IC regulator is unplugged and a couple of jumper wires are installed on the machine side of the regulator plug.
6,594
Check the envelope top right. ;)
TimAT
Oct 5, 2023
36
Kansas City. MO
I got my hands on the installation instructions for the B7324 conversion kit. But no diagram that shows the wire diagram. Instructions only show how to route the harness.
2,828
1,544
From Googling 'Kubota B7324', it appears that kit also fits the B3030 and other tractors. There is a WSM for the B3030 at kubotabooks.com. Does your alternator have RY (red w/yellow stripe) and WR (white w/red stripe) wires and internal regulator? If so, it looks like the charge light should be connected between those two wires.
TimAT
Oct 5, 2023
36
Kansas City. MO
Thanks.. Very helpful. at least I know how it is supposed to work. My alternator is at the hospital right now, should have it back in a couple of days. It is an internal regulator type. Chasing the wires, the original sky blue wires from the dynamo have been used to get the field and the sense wires to the dash, and the alternator output is directly to the main battery terminal on the starter thru a 50A fuse.
TimAT
Oct 5, 2023
36
Kansas City. MO
Update: I found this thread about the Dynamo to Alternator upgrade.
I had all of the parts required except for the 4 pin relay, so I used a 5 pin relay and socket, just cap and stow the extra wire off the relay.
Now the charge light works as it should. I did add this diagram and parts list to my GF1800 WSM for future use,
On to the next little project.
