F fis42h New member Equipment Kubota B6200 Dec 9, 2024 2 0 1 Rapid City, Michigan Dec 9, 2024 #1 I want to change gear box oil, but I can't locate the oil drain or refill plugs, on model B2551 snowblower. Any help would be appreciated. Thanks
North Idaho Wolfman Moderator Staff member Lifetime Member Equipment L3450DT-GST, Woods FEL, B7100 HSD, FEL, 60" SB, 743 Bobcat with V2203, and more Jun 9, 2013 30,537 6,594 113 Sandpoint, ID Dec 9, 2024 #2 There is only a plug on top, you will have to turn it upside down to drain it. Reactions: 1 user
F fis42h New member Equipment Kubota B6200 Dec 9, 2024 2 0 1 Rapid City, Michigan Dec 11, 2024 #3 North Idaho Wolfman said: There is only a plug on top, you will have to turn it upside down to drain it. Click to expand... I saw that plug, but I couldn't find the drain plug. At least now I can check the oil level. Thanks for Ur reply
G GreensvilleJay Well-known member Equipment BX23-S,57 A-C D-14,58 A-C D-14, 57 A-C D-14,tiller,cults,Millcreek 25G spreader, Apr 2, 2019 11,652 5,042 113 Greensville,Ontario,Canada Dec 12, 2024 #4 or... suck it out with a straw All I can see is a day lost getting the SB upside down, 2 cups of oil all over everything and a 1/2 box of bandaids needed.......
