SPL 0548 Snow Pusher assembly
naturalgas
BX 25
Feb 15, 2016
10
metrowest, Ma.
A local Kubota dealer will sell me a SPL0548 snow pusher for my BX23S for $300 less if I take it in the crate and assemble it myself. I’m a backyard mechanic and figure it should be a fairly simple assembly job. Am I correct in this assumption or should I have them do it?
6,594
Super simple assembly!
No moving parts.
2,912
It couldn't be that difficult.
I would save the 300 bones for sure.
(actually I would save it, just to spend it on more_______________ (fill in the blank....Guns, ammo, rum, steel, aluminum, tools, plasma cutter consumables, cigars, safes, lathes, DRO's.......there are alot better things to spend 300 bucks on) (y)
I should have been a Congressman or Senator........those guys know how to piss money away BIGLY!
BAP
Dec 31, 2012
2,787
898
I would definitely jump on the deal if you have some wrenches. It shouldn’t need much assembly and all it would be is bolting on some metal pieces. Here is a link to the Operators Manual and in it, it shows quite a bit about what needs bolting on during setup.
Bearcatrp
Mar 28, 2023
683
364
Minnesota
What is the width of it? I bought a closed top version in 48 inches wide 2 years ago for $1400. The new ones with open top are a little over $1000 from what I just looked at. I have a gravel driveway. My pusher sinks into the ground due to thin skis. Being an open top it could be lighter. Let us know how well it works for you
4,870
The closed top was an option at one time. Don't know if it still is. I toyed with buying one, but decided against it in favor of a snowblower and plow.
Bearcatrp
Mar 28, 2023
683
364
Minnesota
They work great on asphalt or cement driveways. But pushing off on the sides where soft could be an issues. If you get one, make sure the skis are wide and adjustable.
AKguy09
LX3310/ Cab 1950 F- Cub
Nov 22, 2017
108
47
ellicott, colorado
I just Bought an 1260 snowpusher and if i could have saved $300 assembling it myself i would have. 3 bolts per skid shoe and about 8 plow bolt in the cutting edge
