Hi Folks,
I recently acquired a tractor/skid steer plow with single-line hydraulic cylinders. The cylinder lines appear to feed into a cross over relief valve before heading to the male and female hydraulic connections. On my tractor, an MX5100, I've installed front end remotes operated from a spool valve and controlled at the joystick. I With this setup, I'm unable to operate the plow as the cylinders end up fighting against each other. The plow setup is a Diamond by Meyer build specifically for tractors and skidsteer which I purchased secondhand w/out seeing it operate first. I've attached some pics and am hoping somebody can help sort out what I'm doing wrong and what plumbing detail I need to add. Any help would be appreciated
