Good golly miss molly..no up pressure on FEL
arml
B5100e BX2200 JD455AWS G1800
Jan 27, 2022
223
236
Pennsylvania
So I go out today to gather up more logs to split...load the bucket go to lift....ooopps....no up on loader...was working fine the day before....fluid check good....wth....this is on my BX 2200 . Not overloaded. Just when the cold is starting to visit...I just don't need this right now.
6,932
Do you hear any noise when trying to lift?
First thing I would do is disconnect then reconnect the couplers for the loader.
5,392
I assume it lifted when you drove to the pickup point?
Does the bucket curl and dump?
GrumpyFarmer
4,067
I am not familiar with your model, but I check the loader lock out before I check the hoses. Someway somehow I have managed (more than once🙄) to move my loader lock lever unintentionally and it gave me an OF moment. That’s easy to check.
InTheWoods
B7510/FEL, B7100D, ZD18, ASK-R130
Nov 17, 2023
244
191
Indiana
First thing I'd do is make sure the 3-point hitch control lever is in the center (neutral) position...
arml
Jan 27, 2022
223
236
Pennsylvania
Well, can't figure it....came out early this morning....walked across the field where the BX was resting....started it up, about 5 min latter I tried the bucket lift....yipe
up no problem, the logs still loaded on. Go figure. Not gonna complain...I'm moving on. Sigh of relief. Gonna do my happy dance with a nice bourbon...relax.
InTheWoods
Nov 17, 2023
244
191
Indiana
Well, can't figure it.....
Again...
If you're not aware - the 3PH control does affect the FEL hydraulics. When you use the FEL, the 3PH control needs to be in the central (neutral) position.
Tractor Gal
BX23D MLB
Oct 30, 2020
591
240
NC
Thanks for the chuckle..."Good golly, Miss Molly". :) My age is showing!
Tractor Gal
