L6060 Turf Tires
6,599
There is 4 possible front tires and 3 possible rear tires, is there a specific set that you want, or just any set?
Location will help tremendously.
Have you tried to acquire them from a dealer, go though sales as whole goods and not through parts.
kj1211
L6060
Nov 29, 2024
I would like the best combo for sand, any suggestions appreciated. I am in SE Ohio, have not tried a dealer yet, I am in SE Ohio. Thanks
6,599
Ok, so you want wide!
Do you need pulling power or float?
Field work, Turf work, Loader work?
There are better option for flotation if you need pulling power too.
kj1211
L6060
Nov 29, 2024
Has utility tires, I use it a couple times a year pulling dock and boat hoists, beach is very sandy. Tractor has a tough time not getting stuck
6,599
Don't know what you call utility tires?
Here are a couple examples:
AG / R1 tires: typically tall and narrow with narrow tread.
Industrial / R4 tires: Typically tall and a little wider with flat fat tread.
Turf / R3
woodman55
L6060HSTC, RTV 1100
May 15, 2022
937
733
canada
R14's would be a option also. Plus being a radial he could air them down a long way for better flotation/traction.
I have seem them at dealers on the L6060's and the MX6000's
kj1211
L6060
Nov 29, 2024
R4's Came new on this Tractor, I called them "Industrial" as they look like tires on some of the Wheel loaders we use
6,599
R14's are much more aggresive than the R4's and you could mount them on the same rims, so cheaper to do.
Turf's would require new rims.
and traction would be much lower than R14's, but flotation might be better.
If you tell me what size tires are on it now I can tell you the R14 sizes to use.
kj1211
L6060
Nov 29, 2024
Left the cottage in Michigan this AM where the L6060 is, will be back up there in a couple weeks, not sure of size without looking. I think the rears are 17.5Lx24 best guess, I am told by local dealer near the cottage that the Flotation Tires are best choice for the loose sand. Thanks
6,599
Yea if you want turfs for flotation you have multiple choices.
But you'll need new rims.
LXHobbyFM
LX2610/Deere 85
Jan 11, 2024
N. Illinois
KJ - I had a deal fall through on a L6060 and had already bought up a set of used turfs/rims beforehand. Not in perfect shape (note: fronts have outer tread wear), but I'd let them go cheap if you're interested. Northern IL/west of Chicago.
Edit: 29x12.50-15 R3 Titan Multi Trac
44x18-20 R3 Titan Multi Trac
